HA/GR transmission
Discussion in 'HA/GR' started by Ron Golden, Jun 6, 2009.
  1. Ron Golden
    Ron Golden
    Guys,
    How many guys in the midwest area are running manual transmissions in their HA/GR cars?
    How many are running automatics?
    Thanks,
    Ron
  2. butch nassau
    butch nassau
    Automatic...turbo 350
  3. bobw
    bobw
    Manual, 4 speed, until it breaks or I find out I'm a h.s. shifter.
  4. Joe Hamby
    Joe Hamby
    Manual, 4 speed with/jack*** shifter
  5. Ron Golden
    Ron Golden
    I thought we were the only one running a manual ******. If/when ours breaks we're going to an automatic. I'm tired of the uncontrobable wheelspin, lousy 60 foot times and the missed 2nd gear shifts. Like Roy (348 Chevy) said, his car leaves without wheelspin and runs some good ET's. We have plenty of power (120+ mph)but can't hook it to the pavement.
    Sounds like a good winter project.
    Ron
  6. ThingyM
    ThingyM
    Ron.. With the HP. you guys are making.. No 6" tire is going to hook up. Manual or Auto. You need slicks...
  7. Toymaker
    Toymaker
    from Fresno,CA
    Ron, I'm not wanting to be a smart *** but that's the reason I like the rule. A little guy like us has a chance when you miss a shift:D Rocky
  8. REJ
    REJ
    from FLA
    Yes, that is another rule that helps level the playing field.
    The other one is the 6" bias ply tires.
    Robert
  9. Toymaker
    Toymaker
    from Fresno,CA
    Robert, looks like you need both tires on the RH side:D Rocky
  10. REJ
    REJ
    from FLA
    That is an idea:eek:. It says we have to run bias plies, but it does not say how many.
    Maybe I can make an adapter and run two on the right side and one on the other, it ought to hook up a little better!!:D
    Robert
  11. ThingyM
    ThingyM
    Yea Rocky, He gets wheel spin.. I won't be able to even get the right side to break loose. Even with 4lbs more pressure on that side.. hehehehe...****..
  12. vectorsolid
    vectorsolid
    from Montana
    and THAT is the sign of a true racer. :D
