Hair pin help !
Discussion in 'The Hokey Ass Message Board' started by V4F, Dec 3, 2012.
  1. V4F
    V4F
    from middle ca.
    has anyone put hair pins on a (4" drop) stock model "A" front end ?it seems i cant get past the drag link ............ thanks .. steve
  2. Harms Way
    Harms Way
    That has always been my experience.
  3. V4F
    V4F
    from middle ca.
  4. V4F
    V4F
    from middle ca.
    sure could use an idea on this .................... thanks
  5. Harms Way
    Harms Way
    Can you post some pictures ?,...
    Did this one a few years ago
    Here's the most recent one we did.
  6. V4F
    V4F
    from middle ca.
    i can post tomorrow . do you have a pic from the front ? what type of steering are you using ?
  7. Harms Way
    Harms Way
    I have used different type of steering mostly 1956 F-1 and Vega.
  8. V4F
    V4F
    from middle ca.
    thanks . pix coming this morning ................ steve
  9. Weedburner 40
    Weedburner 40
    Steve, I have hairpins on my tub with no problems. Using Vega steering with double eyed steering arm on p***enger spindle.
  10. crminal
    crminal
    You are using stock A spindles?
  11. Model A Gomez
    Model A Gomez
    I'm building a 30 coupe with a 4" dropped axle, hairpins, a 51 F1 box and Speedway upper steering arm for the draglink and everything clears.
  12. V4F
    V4F
    from middle ca.
    yes stock "A" spindles with '42 hyd brakes . stock steering box ....... thanks for your help .... steve
    pix today .
  13. I know this is not help but I have always used cross steer with hairpins.
    Where is your interference perhaps on the A you will need to bend your steering arms.
  14. V4F
    V4F
    from middle ca.
    ok , im back . pix here
    yes some of the pix are dark & yes i know my steering box leaks .
    now it hits the tie rod ......... hmmmmmmmmmmmm
  15. V4F
    V4F
    from middle ca.
    still need a little help .................... thanks
  16. el Scotto
    el Scotto
    from Tracy, CA
    Heat and bend, my friend! :cool:
  17. crminal
    crminal
    X2 it's the early spindle design. Heat and bend till clearance occurs.
  18. V4F
    V4F
    from middle ca.
    i think i need to bend the pitman arm also .......... ??
  19. V4F
    V4F
    from middle ca.
    thanks you guys !
  20. V4F
    V4F
    from middle ca.
    got me a torch & goin to work ............. thanks all ................... steve
  21. MATACONCEPTS
    MATACONCEPTS
    Try fliping the pitman arm around.
  22. crminal
    crminal
    Steve, I think that you can flip the ball joint to the bottom of the arm. Re-taper the hole and put it in from the bottom. Then. Your tie rod can go through the center of the hairpin like it is intended.
    Whadayathink?
  23. V4F
    V4F
    from middle ca.
    hmmmmm good food for thought . ill look at both ideas . thanks
