Technical Hairpin vs split wishbone
Discussion in 'Traditional Hot Rods' started by angelbaby65, Apr 12, 2022.
  1. alchemy
    alchemy
    But Denny, just imagine how much better that coupe would look with some chrome hairpins.
  2. DDDenny
    Ten-Four!
  3. -Brent-
    -Brent-
    Bones are cool. Hairpins are cool. There are tons of examples of each. There are crude and elegant versions of each, too.
    I wanted a little bit of both and used 1932 wishbone as donors for my batwings. I got a little grief for that, hahaha.
    We actually had a set of batwings for comparison and reference for these.
    PSX_20200324_203009.jpg FullSizeR(1).jpg FullSizeR.jpg IMG_7284.JPG IMG_7330(1).JPG PSX_20200707_102035.jpg
    Also. Check out @B*** and how he fabbed his batwings from Ford wishbone.
    Sometimes, batwings are a necessity depending on your unique setup.
    Still, I wouldn't worry about yours. Lots of folks running them.
  4. Blues4U
    Blues4U
    from So Cal
    Pro: The axle doesn't move in an arc as it travels up & down when the suspension works; this gives an improved ride and eliminated bump steer due to improper steering geometry.
    Con: Poor aesthetics. Not much looks worse on a fenderless rod than 4-bar radius arms. If you're running fenders and running boards the 4-bars are hidden behind the fenders and this isn't a problem. Or, some guys don't mind the look anyway. I hate it.
  5. Blues4U
    Blues4U
    from So Cal
    Send them to me!
  6. Blues4U
    Blues4U
    from So Cal
    If you change to split bones, you're going to have to address the issue that @Hot Rods Ta Hell mentioned above. You're going to have to drop the steering arms so the drag link and tie rod will run below the bones. According to this photo you've got chromed steering arms. The chrome will be ruined in the process of heating and dropping those arms. So you've got more work and costs beyond just the bones. For what? If it's just aesthetics, you don't like the way the hairpins look, then it's up to you if it's worth making the change. If it's about safety, then you're wasting your time & money, the hairpin set up is plenty strong for the application, has been used on countless race cars and hot rods going back as early as the 30's, maybe earlier.
    -Brent- and mad mikey like this.
  7. alchemy
    alchemy
    If you are worried about safety and strength, you should surely take a look at how far threads are reaching inside the tie rod and drag link tubes.
  8. tubman
    tubman
    I've had two cars with this type of front suspension. The first had split bones, the current one has hairpins. I much prefer the wishbones, as I think they look a lot better (think "Kurtis-Kraft") and they are adjustable.
    If you can't build an ***embly that has enough threads inside of the components, it's time for a new hobby.
    rod1, 2OLD2FAST and 26 T Ford RPU like this.
  9. angelbaby65
    angelbaby65
    Thanks for all of the input guys! I’m come from the rock crawling world so these thin single shear brackets make me worry!!!
  10. v860rich
    v860rich
    I built my roadster in 1963 with hair pins.
    I've only had a problem one time and that was on a very hot parking lot in Tulsa, when I tried to stop with my front wheels between two lines about a foot apart, the asphalt was actually melting apart and had turned to a tar patch the rt. side tire stopped but the rest of the car didn't!!
    The rt. side hair pin wadded it self up, bad.
    We got it straighten enough to make it back to eastern MO.
    When I built the new set I just filled in between the upper and lower cord with my initials.
  11. You may want to get a shorter front spring to get the shackles at a better angle. JW
    sloppy jalopies likes this.
  12. Dave G in Gansevoort
    from Upstate NY
    A concern I have with hairpins, and before you ask yes I'm using them on the Whatever project, is the typical clevis used has a 5/8-18 threaded end (More than adequate), but is drilled for 3/8 bolts to attach to the batwing. I just think it's a tiny bit too small. Especially if you don't ensure that the bolt threads don't end up in shear.
    I am using spherical rod ends that have the 5/8 shank and a 1/2 bore, again making sure that the threads are not in shear. It means either buying bolts from a specialty supplier or starting with a bolt that has the correct length for the solid shank and shorten the threaded end to suit.
    This is just my opinion. Take it for what it's worth.
    26 T Ford RPU likes this.
  13. blue 49
    blue 49
    from Iowa
    My '36 has a basic Speedway hairpin kit. I hit a car that turned in front of me with my right front tire. The wheel was forced around into the right hairpin and mangled it pretty good. The batwings survived just fine and the clevises looked OK (I replaced the clevises, anyway). A hard enough hit that it bent and twisted the sector shaft on my GM Vega steering box.
    Gary
  14. hipojoe
    hipojoe
    So for typical driving all systems will work just fine other then aesthetics, which will put a build into a certain time frame when these different systems were typically used in... 50s 60s 70s?
  15. alchemy
    alchemy
    Your REALLY need to mount that brake line better. The end of the steel, where it mounts to the hose, needs to be solid. Not hanging in mid air.
  16. dumprat
    dumprat
    from b.c.
    I'm always curious why more people don't run bushed ends on hairpins instead of the clevis type. A bushing will help with ride and provide a lot more flexibility of suspension movement and way less bind.
    A Boner likes this.
  17. No kids could afford hairpins in the 50's Split wishbones was the thing.
