I'm trying to find out what the fluid capacity is for each cavity of a Champ rearend in pints if possible. Also, can both cavities be filled through the cover hole? Thanks.
Dean, This article at the end says 3 quarts http://www.jalopyjournal.com/forum/showthread.php?t=148241
Heres another link with some information as well http://www.jalopyjournal.com/forum/s...d.php?t=225131 <!-- / message --><!-- sig -->
And a few other references http://www.jalopyjournal.com/forum/showthread.php?t=609495 http://www.project33.com/article.cfm?ID=133 http://www.cmwraceparts.com/d/Winters-FAQ.pdf
My Halibrand chart for a V8 quickchange says "The change gear grease reservoir is separate from the ring and pinion grease reservoir. Fill each with EP90 or 120 grease up to the level of the plug." I don't know if a champ QC is any different. JimSig
