History Halibrand qc 2sp ?
Discussion in 'Traditional Hot Rods' started by Bigbrowntrout, Feb 6, 2026.
  1. Bigbrowntrout
    Bigbrowntrout
    Has anyone ever seen one of these or know anything about it ? Thank you
    tractorguy, Budget36 and 51 mercules like this.
  2. patsurf
    patsurf
    well i sure want to hear about it!!
    Bigbrowntrout likes this.
  3. Woodworker21
    Woodworker21
    I am with patsurf . I sure would like to hear about it.
  4. jaracer
    jaracer
    Whatever that device is, it is mounted where the pinion gear p***es through the case. I don't know how that could make a 2 speed.
    saltflats likes this.
  5. DDDenny
    I really don't know much about them but if I recall that is an In/Out Hal.
  6. Bigbrowntrout
    Bigbrowntrout
    Another older guy told me it was made for Indy type cars going in and out of the pits ???
  7. DDDenny
    This is the one I was thinking about, the lever location is different........don't know!
    Just Gary likes this.
  8. Bigbrowntrout
    Bigbrowntrout
    Looks like it could be the same principle though.....
  9. redo32
    redo32
    Some place on the HAMB is a thread about Halibrand 2 speed rear ends. The search function ****s, you have to use the proper words or phrase. There was a story about Roger Ward showing up at a sports car race with his miget and they laughed at him with his in-out gearbox. He proceeded to show them the way home with his 2 speed rearend. Pat Warren in LA made a copy of the Halibrand quickchange rear and he devised his own 2sp gearcase that bolted to the rear of his and Halibrand's QC. I have one of his setups missing the mainshaft.
  10. Bigbrowntrout
    Bigbrowntrout
    Can you post a photo ?
  11. 19Eddy30
    19Eddy30
    from VA
    @redo32
    Interesting ,, if I thinking correct
    The 2 speed part ,
    does it over drive or underdrive
    Let say if you have the two gears set up for 4:00 What does it change to when
    Engaged ?
  12. redo32
    redo32
    @19Eddy30 there are different sets for different ratios. I don't have a chart.
    swifty likes this.
  13. jaracer
    jaracer
    That has a slider on the lower shaft so you can connect and disconnect the lower shaft. On sprint cars, it allows you to do away with your in and out box. With no in and out box, the front u-joint is bolted directly to the crank flange. That also means the torque tube can be longer (the length of the deleted in and out box)which is supposed to give you better forward traction.
  14. jaracer
    jaracer
    That makes sense. The back gear housing has to be a bit deeper to accomodate the extra gears. So the gears on the lower shaft have to be retained by either a bushing or a bearing. The slider locks one or the other on the lower shaft.
  15. DDDenny
    Here:
    https://www.jalopyjournal.com/forum/threads/what-is-this-quick-change-rear-end.1301340/
    I've always used Google, not the HAMB search function, include HAMB in your search, always (usually) gets results.
    CoolForSchool58 and Outback like this.
  16. redo32
    redo32
    Thanks @DDDenny, I need to get into the habit of searching like that.
  17. Bigbrowntrout
    Bigbrowntrout
    I wonder who could build one today ? Does anyone have any thoughts ?
  18. patsurf
    patsurf
    kevin pharis!
    Outback and Bigbrowntrout like this.
  19. Bigbrowntrout
    Bigbrowntrout
  20. patsurf
    patsurf
    look on here about building a winfeld
    Outback likes this.
  21. Bigbrowntrout
    Bigbrowntrout
    Don't know what that is ?
  22. billfunk29
    billfunk29
    from Minnesota
    I recall a youtube video about two speed quick changes. Can't find it now. They said that there only half a dozen 2 spd V8 versions made.
    Outback likes this.
  23. Bigbrowntrout
    Bigbrowntrout
  24. $um Fun
    $um Fun
    from Nor Cal
    To set the record straight, Ted Halibrand worked for Pat warren at Downey Machine as a pattern maker and copied the Pat Warren quick change when he left to start Halibrand Engineering. Not the other way around.
    Outback and Fordors like this.
  25. Bigbrowntrout
    Bigbrowntrout
    They both would be a good one never the less......
  26. redo32
    redo32
    Cool. Thanks. I didn't know that.
    Outback likes this.
  27. Magfiend
    Magfiend
    I have a bare 2 speed Halibrand case for sale...
    20230612_144456.jpg 20230612_144433.jpg 20230612_144442.jpg 20230612_144445.jpg 20230612_144439.jpg
    51 mercules likes this.
