Hot Rods Halibrand question
Discussion in 'The Hokey Ass Message Board' started by Chris Haynes, Jun 15, 2024.
  1. [​IMG] I just bought a Halibrand 101. The studs that attach the axle housings are much smaller than the the Ford bolts that hold the housings to the center section. This leaves a lot of slop. Did they use nuts with a step in them to fill the gap?
  2. alchemy
    alchemy
  3. gimpyshotrods
    gimpyshotrods
    They are located by the shoulder, not the fasteners.
    Just make sure the nuts are proper torqued.
  4. Ken Smith
    Ken Smith
    Alliance Vendor
    The 101 studs are typically 5/16”. Is that what yours are? The Ford bolts are 3/8”. The Halibrand 101 was made to use their own side bells, which had 5/16” holes. Typically for midget race cars. If you’re going to use a torque tube, you’ll probably have to modify the holes to fit. The bolt circle is slightly different.
  5. Tim
    Tim
    from KCMO
    101 uses model A banjo stuff and 4 cylinder 32. That may be where the difference lies
  6. Marty Strode
    Marty Strode
    This 101 had 3/8 studs as I remember, but it was a special one that used V-8 change gears. Ed 2.jpg
