History Halibrand Quick Change age
Discussion in 'Traditional Hot Rods' started by Matt Spencer, Nov 3, 2016.
  1. Matt Spencer
    Matt Spencer
    Does any one know how to tell the age of these?
    The one with the boss on the side has D307 stamped on it
    And the other has D235A stamped on it
  2. ronnieroadster
    ronnieroadster
    Not sure about actual production dates but. The housing on the right is an early casting notice there's no internal support rib running front to back along the top and bottom like the housing on the left. The housing on the left is a much stronger design I purchased a new one identical to that one from Halibrand in the early 70's cost a lot $225.00 including one set of change gears. Still running it to this day.
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'm no expert on 201 Halibrands, but my understanding is that the square boss indicates a Culver City case. That would be pre-1963. Did not know about the internal rib. I'm interested in the 'D**x' markings. Do either of the cases or rear covers have any city of manufacture cast into them?
  4. Matt Spencer
    Matt Spencer
    I have added a pick of the covers.
    They both have
    HALIBRAND ENG
    CULVER CITY, CAL
    on the bottom and the one on the left has
    H-102 cast on the top upside down.
    You can see that there are raised boss for the plug on the one on the left as well.
  5. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The H102 would designate that it was on a Midget rear originally. (Model Astyle) The rear covers are interchangeable from H101 and H201 cases. The Midget rear cover may have smaller O.D. bearings.
    That about exhausts what I can tell you about what you have.
  6. Matt Spencer
    Matt Spencer
    Thanks
    I did ckeck the bearing size and they are the same. (6304)
  7. 383deuce
    383deuce
    Very cool quick changes to have bud......Wish I had one.
  8. pinman 39
    pinman 39
    Just in case anyone is interested
    I have a complete Model A quick change with an extra set of gears that I would like to sell
    I plan to get it listed in the next day or two pm me if interested .
    Avgas likes this.
  9. Corn Fed
    Corn Fed
    I have a magnesium 201 with the square blocks on the case sides and it has a number hand stamped along the bottom rib that starts with an LR and is followed by 4 numbers and another letter. I'd have to look at it again to get the exact info. It has an aftermarket cover on it so that is no help with dating it.
  10. Old Tin and New Tin
    Old Tin and New Tin
    BTT, someone out there hopefully can add information with regard to age identification. Frames, are you out there?
  11. Distracted
    Distracted
    After you decide which one to use you should give your buddy the one you don't need. Just saying.
