Hot Rods Halibrand Quick Change
Discussion in 'The Hokey Ass Message Board' started by Bob Kirk, May 25, 2025.
  1. Bob Kirk
    Bob Kirk
    I have a Halibrand quick change in my 1953 Chevy 3100 Pickup. I have been unable to get the rear end to stop dripping. The rear seal (where the drive shaft connects) continue to drip constantly. I highly suspect that the bearing are shot. Does anyone know of a shop still in existence, that can be trusted to rebuild this unit for me, ***uming parts are still available.
    Thanks
    Bob
    ydopen, seb fontana and chryslerfan55 like this.
  2. krylon32
    krylon32
    from Nebraska
    Gearhead QCE on here should be able to help or get you going in the right direction.
  3. jimpopper
    jimpopper
    Check with your local dirt track racers. They run variations of it and should be able to point you to a good local rebuilder.
    ydopen and lothiandon1940 like this.
  4. Rickybop
    Rickybop
    Where are you so maybe someone knows of somebody near you.
    A Boner likes this.
  5. Tim
    Tim
    from KCMO
    Where are you located?
  6. uncle buck
    uncle buck
    Make sure the differential is vented and also the vent is not in the actual center section where it would sling oil at it
    winduptoy and brigrat like this.
  7. Frames
    Frames
    Gear oil weeps down the splines. Use Permatex on the large washer that holds the U joint on.
    rod1 likes this.
  8. Bob Kirk
    Bob Kirk
    Northeast of Dallas Texas.
  9. Tim
    Tim
    from KCMO
    Brian B*** is the Dallas area. If anyone is going to get something dead on correct it’s him.
  10. Tim
    Tim
    from KCMO
  11. swifty
    swifty
    @Frames is correct. I had same problem with my Halibrand, replaced the seal and still had the leak. Ended up cutting a gasket the same diameter of the washer and no leaks since. Frames solution probably easier than mine.
  12. Bob Kirk
    Bob Kirk
    Today, I pulled the driveshaft to get a better look at where the oil is coming from. When I removed the center bolt and large washer, the spines were dry. However, when I removed the yoke, oil came pouring out. Also, I see no evidence of a breather hole in the Halibrand case, it is labeled as a model 201, if that makes a difference. See photos at the link below:
    http://53chevy.rfk.sent.com/Halibrand/
  13. alchemy
    alchemy
    I’m surprised to see a V8 size quicky under a fat Chevy pickup. But anyway, there should be a vent installed in one of the axle housing tubes, not the aluminum housing. If you don’t find one, put one in. It’s common for the vent to actually be the attaching bolt for the brake line junction block.
  14. krylon32
    krylon32
    from Nebraska
    As for the breather I always put a breather in the left tube a few inches out from the bell is welded to the tube.
  15. neilswheels
    neilswheels
    from England
    The vent wouldn't be on the center section, it would normally be on top of one of the bells, maybe half way along.
    Ive tried to find more info, but its thin. I did find this tho
    https://www.project33.com/article.cfm?ID=132
    I know the shop that built mine drilled and tapped a bell, and screwed a vent in
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I've not had that experience with the 201 but just because I don't work on that many of them.
    Definitely seal the splines to the yoke.
    I have had 301s that wouldn't stop leaking until they had a speedy sleeve installed, even though they didn't show any signs if wear.
    Be sure to grease the seal before installing the yoke. A dry start up will knock the edge off.
  17. Bob Kirk
    Bob Kirk
    It is an interesting 53 Chevy. The guy who started its hotrod resto mod has p***ed away, but he acquired the Halibrand, a McCulloch supercharger from a 57' Studebaker, a Vertex magneto, and a 4 speed ****** from a 67 Camaro and a T&F shifter. I have done a full restore, but want to keep all these unique parts.
    I have no talked to Brian B*** here in Dallas. The culprit for all my leaking isn't coming from the splined shaft, rather it is dripping through the sides of the shaft bearing. Check out the photos at this link and you can see the oil dripping out constantly.
    HemiDeuce likes this.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That bearing should have seals on both sides. Also, install it with RTV on the outside. You still might need a speedy sleeve and new seal.
  19. Bob Kirk
    Bob Kirk
    In order to get this rig to a car show on Saturday without it draining all over the street, I have a new seal on way, should be here tomorrow, and then I am going to RTV the **** out of that bearing and see if I can stem the flow of gear oil for a bit.
