Hot Rods halibrand wheel plates?
Discussion in 'The Hokey Ass Message Board' started by woodyTom, Feb 5, 2016.
  1. woodyTom
    woodyTom
    from canton MI
    does anyone know where i can get a set of flat plates for my halibrand wheels? thanks tom
  2. alchemy
    alchemy
  3. maneri
    maneri
    from ohio
    someone on the hamb made/sells them --in the past --I think for ET III's--the same
  4. dreracecar
    dreracecar
    from so-cal
    OK, what flat plates are you refering to? to cover up multi hole wheels ? or to replace the spindle cover? Whatever Ive done both and its just a simple machine job
  5. I think that this is the simplest solution.^^^^^
    a wheel plate is also what we used to call a flat spyder cap, correct?
  6. beatnik
    beatnik
  7. dreracecar
    dreracecar
    from so-cal
    But the OP refers to "Halibrands" and since those are race type wheels I dont recall spyder caps being used, so there is some confusion happening
  8. woodyTom
    woodyTom
    from canton MI
    thanks got the help, found them........................
