Hot Rods halibrand
Discussion in 'The Hokey Ass Message Board' started by 37chevyman, Dec 16, 2022.
Tags:
  1. 37chevyman
    37chevyman
    from ga.
    has anyone bought any hailbrand wheel for holley, good are bad
  2. alchemy
    alchemy
    You mean Halibrand. Might get better search results with proper spelling.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. Mr48chev
    ekimneirbo likes this.
  5. bobkatrods
    bobkatrods
    from aledo tx
    Also in the 5 spoke design they are using screws just like American for the center caps
  6. DDDenny
    Say it isn't so!
    Must not been able to find machinists that know how to cut threads.
  7. krylon32
    krylon32
    from Nebraska
    Might take a look at American Rebel. I know they're having some growing pains but produce a good wheel. I'm putting 15X4's and 15X10's on my new deuce sedan. Excellent quality and polishing.
  8. Dean Lowe
    Dean Lowe
    Yeah, I retired. :D
  9. PotvinV8
    PotvinV8
    After they were aquired by Holley, they released a new wheel design for Teslas and an Indy Roadster "style" wheel for Squarebody trucks. This speaks volumes as for whom they consider their "customer". It's as if they grabbed a catalog from the early '60s and said, "let's make wheels in every size, EXCEPT these". No skinny 16s, no skinny 18s. Hopefully this changes...
    lothiandon1940, A Boner and Tman like this.
  10. It won't.
  11. PotvinV8
    PotvinV8
    I know, but I was trying to be positive, it being Friday and all. LOL
    lothiandon1940 and Tman like this.
  12. kabinenroller
    kabinenroller
    I have American Rebel wheels on my Cyclone, they look about as close to a “real” Halibrand as could be. Great quality and timely service when buying direct.
  13. DDDenny
    Me too Dean but I bet we both still know how to cut threads.
  14. gimpyshotrods
    gimpyshotrods
    My CNC machine knows how to cut threads. I just need to tell it where, what diameter and pitch, and how deep.
    I know how to, as well, but I make the machine do it.
    I bring this up because the CNC machine that did the rest of the work on these wheels could have also just as easily made these these to match the originals.
    Not doing this was a choice, likely rooted in saving on production costs.
    Tman likes this.
  15. Dean Lowe
    Dean Lowe
    But could you do it on a 1953 Logan lathe?
    deucemac, Jim Bouchard and 1320 Fan like this.
  16. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I recently bought a set for the old truck from Holley. I am happy with them and the service was great. I made my own covers for the center of the rear wheels and I modified the front wheels to use a bullet like center.
  17. WZ JUNK
    WZ JUNK
    from Neosho, MO
    Large rear wheels are heavy and difficult to align and start the lug nuts. 15C4A12B-00F6-4E7F-81EF-524F176CAA75_1_105_c-resized.jpeg
    I made 2 of these to help align the wheel lug holes to the studs. I ground the hex off of two old shoulder style lug nuts and cut a slot in the top with a cutoff tool. You instal two of these on the studs, then slide the wheel on, and start 3 regular shoulder style lug nuts. Then you remove the two starter pins with a screwdriver, and replace them with lug nuts.
    deucemac, Kiwi Kev, Budget36 and 16 others like this.
  18. kadillackid
    kadillackid
    Great idea ... :rolleyes:
  19. gimpyshotrods
    gimpyshotrods
    Yes, if I had one.
    There is no money to be made in manual work these days, and no space in my shop for a machine that will be used 3-4 times-a-year.
  20. Nice idea!
  21. bobkatrods
    bobkatrods
    from aledo tx
    Have same set, obsolete now, most people are unaware that real Halibrands center caps are threaded on
  22. As Gimpy says, not much call for a machine that is used 3-4 times a year. I moved to Pennsylvania 5 years ago, and it took me a while to find a small one man shop to do onesy-twosy's work for me. I found a great machinist about 20 minutes from me. He is in his early 50's, I am in my early 80's. Hopefully he will be around for a long time. The only welders that I have found are used to doing work on farm equipment. I still send welding work to my welder in Connecticut. He is good, quick, and in-expensive.
