Technical Halogen sealed-beam suggestion for B-L-C 682-J buckets
Discussion in 'Traditional Hot Rods' started by Detonator, Sep 27, 2022.
  1. Detonator
    Detonator
    from santa cruz
    Are you running Halogen sealed-beams in your B-L-C buckets? What brand?
    I pulled the original 12V sealed beams out of my B-L-C 682-J headlight buckets, thinking I'd replace them with brighter, Halogen sealed-beam lamps. If you're familiar with these headlamps, they have three tabs cast into the gl*** to help position the bulb in the bucket. The bucket has three slots that accept these tabs.
    I bought pair of Sylvania Halogens and the tabs are way too big for the slots. I always ***umed Halogens and standard sealed-beams are directly interchangeable. Is the problem the Sylvania brand? Did you have success with another manufacturer?
    I'm hoping I can find a drop-in headlight before I start grinding on these nice buckets.
    Thanks
  2. goldmountain
    goldmountain
    If your Sylvania lights have metal reflectors, you could file them to fit.
    lowrd likes this.
  3. alchemy
    alchemy
    I must be a "correctness snob". Years ago I bought a case of NOS 12V sealed beam inserts so I'd never run out when the rest of the world went to halogen.
    Maybe you can sell your good incandescent bulbs to recoup the cost of your halogens?
    RICH B likes this.
  4. Detonator
    Detonator
    from santa cruz
    No, can't do it, the tabs are cast into the gl*** -- and it would take some considerable reshaping.
    My incandescents are 6V.... and you're right. The 12V incandescents are now getting hard to find. Unless I find a Halogen with old-style tabs, I'll go back to incandescents.
    Atwater Mike and lothiandon1940 like this.
  5. pprather
    pprather
  6. goldmountain
    goldmountain
    Try to find another set of lights. When the car manufacturers went to seal beams in 1940, it standardized the 7" round seal beam for the next 40 years. Back when I worked at the auto wreckers, I would "harvest" halogen lights for my various cars and they always fit. The ones presently on my T coupe, are Bosch units from second hand shop. I find the ones with a metal reflector and glue on a lens from a vintage metal reflector seal beam for a more correct era look. IMG_0997.JPG
    nunattax likes this.
  7. 31 B'ville
    31 B'ville
    from SE Pa
    I got these at NAPA. They fit my Guide 682-C just fine. 1CD4004D-8409-40E3-A01E-6D8F5468C6D6.jpeg B0798571-8D39-4310-939C-56776760D672.jpeg
    rod1 and caprockfabshop like this.
  8. Hitchhiker
    Hitchhiker
    I think I have Wagners in mine
  9. Sylvania Silver Stars (H6024) fit in my 682 J buckets, but the brighter the light, the shorter the time. I looked at the side of the box when 1 of them went out just under a year (warrantied) and it was something short like 150 hours........regular bulbs where like 300 hours.
  10. J. A. Miller
    J. A. Miller
    from Central NY
    Get a diamond wheel for your angle grinder and trim the gl*** nubs until they fit.
  11. banjorear
    banjorear
    I have the same headlights and the Napa replacement went in without issue.
    31' A Bone likes this.
  12. nunattax
    nunattax
    i fitted cibie units to my 38 truck went straight in without an issue i was very pleased.quality lens will allow you to use bigger bulbs without melting or cracking.c
  13. lowrd
    lowrd
    I’ve used lamps from Cibie, Marchal and Hella. All worked without modifying lamps or housings. Use relays if you go this route. 55/100 watt bulbs are available too.
  14. nunattax
    nunattax
    the brighter the better
  15. Elcohaulic
    Elcohaulic
    Until you blind the oncoming driver.
    The weird thing about this, is when people get blinded, they drive right towards the light that blinding them. The insurance industry has never figured out why either.
    Oh ya, once the insurance agent finds out you modified the lighting system on your car guess what.
    You learn a lot of cool things driving a tow truck.
  16. pprather
    pprather
    @Detonator , lots of suggestions. Have you been able to find a 7" halogen for your headlight buckets?
  17. Atwater Mike
    Atwater Mike
    My 7" Halogen sealed beams came from Kragen's. (That's 20 F100 years ago!)
  18. rdscotty
    rdscotty
    from red deer
    It is called target fixation. People focus so intently on the object they are looking at, they steer toward it.
    Elcohaulic likes this.
  19. 59Apachegail
    59Apachegail
    from New York
    Ned Ludd and pprather like this.
  20. nunattax
    nunattax
    thats not necessarily so here we drive on the left ,our lights dim to the left down and away from the oncoming drivers.so brighter doesnt mean dazzling once they are aimed correct .it just means i can see more of the edge of the road.esp when driving into modern suv s with led lights high up and with extra driving lights on 24/7.im the one being dazzled and gotta upgrade with brighter lights similar to what im facing into.with the winter coming and heading into wet night time driving upgrades are needed brighter upgrades .
    and any issues with insurance and light upgrades at least ill be alive to tell the tale.i upgraded the lighting on my 38 with CIBIE lens,halogen bulbs front . and rear led indicators added stop/tail lights to the original lights with gl*** lens.reflectors.planning reverse lights and a rear fog.all traditional looking with led internals .
    while i dont intend driving my rod during the winter nights you never know when a short trip out could end up being delayed and i intend to be prepared.
    Ned Ludd likes this.
