Technical HAMB help cam ID
Discussion in 'The Hokey Ass Message Board' started by gasshole, Dec 11, 2019.
  1. gasshole
    gasshole
    from new jersey
    I have a solid roller for a small block chevy. The numbers are
    Front CH
    Back 119566SM and 99A26.
    Any help would be greatly appreciated..
    Thank you
  2. Rex_A_Lott
    Rex_A_Lott
    I really cant help, other than to bump the thread.
    A guess might be that the CH stands for Chet Herbert.
    Maybe @Pete1 will see your thread and have some input, he's in the cam business.
    Good Luck.
  3. gasshole
    gasshole
    from new jersey
    Thank you. I thought maybe Chet but its not that old.
  4. dan31
    dan31
    Scott , google says ( for what it's worth) #119556sm is a small base circle Crane cam ,8620 steel billet core. # 94b2a should be quality control marking. Again that's from the internet ,so?. Jerry at Medford speed may be able to help.
  5. gasshole
    gasshole
    from new jersey
    Thank you. its unfortunate but the more I googled the more different answers I found.
  6. Google helps if you know the cam grinder. For instance you could google Chet Herber cam number 119566SM if you believed it was a Chet Herbert cam. I got an idea that it is not a crane, most of the crane cams I have seen had Crane stamped on them.
