HAMB question
Discussion in 'Questions & Suggestions' started by willys36, Nov 4, 2019.
  1. willys36
    willys36
    Is there a way to go to your post in a thread with a bunch of pages without looking at every post?
  2. lothiandon1940
    lothiandon1940
    You can go to your profile page and click on your postings and find it that way.
    Cosmo50, Surfmerc and scrap metal 48 like this.
  3. willys36
    willys36
    Yes, that works for recent posts but for ones that are aged, that is as daunting as thumbing thru the posts in the thread. I am thinking of the 'Artsy' thread that has popped up recently and has 1322 posts, 45 pages. I don't remember when I posted and not thrilled with the thought of looking thru 45 pages!
  4. squirrel
    if you remember a little bit of what the post said, you can use google to search for those words, plus your user name, and the word hamb or jalopyjournal.
    If you find it once, you can get back to it by copying the link "share post #**" that shows up at the bottom of the post. Save that link, and it will take you to that post every time.
  5. willys36
    willys36
    I'll try that. Thanx.
  6. fastcar1953
    fastcar1953
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    click on the torso app in the upper right hand corner of the page and click on "your content"
    Sent from my SM-G973U using The H.A.M.B. mobile app
  8. charleyw
    charleyw
    Thanks Squirrel, I learned something new today.
    "If you find it once, you can get back to it by copying the link "share post #**" that shows up at the bottom of the post. Save that link, and it will take you to that post every time."
  9. Yes search the key words in your post. For example if I wanted yo see a post in a long thread that I made where I mentioned that someone was a "**** waffle" I would search my screen name between **** date and **** date and the key words **** waffle. Then that is what would come up. Well that and no doubt that boss saying that I promised not to call anyone that.
    Stogy likes this.
  10. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Don't think i've ever heard of **** waffle before ?
    will i get my *** kicked if i call someone that ? I'm thinking probably !
    Stogy and lothiandon1940 like this.
  11. Stogy
    Stogy
    Here's what I have done...first be in the thread you want to search...then go to magnifying gl*** search flag and type your screename in posted by member...
    You can add words or a phrase you can remember in the search string (do not select ***les)
    The last is select search this thread only...
    What this does is bring up any posts in that thread with the words you input...
    You don't have to put any search words in and ALL your posts will show up with some text so you could probably spot your post...I have done it and yes searching for old posts can be laborious...but this feature quickly narrows things down...
    Thanks to all the others for their methods...Loth is right, huge threads can be a challenge...
