HAMBER DOWN -- Granbury, TX
Discussion in 'The Hokey Ass Message Board' started by Slide, Oct 4, 2007.
  1. Slide
    Slide
    Just got a call from Dirty31. He said hot_rod_artist (Casey) broke down in the Granbury area just off 377. Looks like he needs an axle from an 8" Maverick rear. He thinks it's the driver side.
    If you're in the area and have something that might work, call Dirty31 (Rusty) at 214-537-7423 or Casey at 512-825-5547.
    Thanks, Yall!
  2. continentaljohn
    continentaljohn
    Just a FYI the 9" is the same with 28 splines wish I was closer best of luck.
  3. flt-blk
    flt-blk
    from IL
    I'm out of town and don't have a spare 8" but will bump in case someone does.
  4. Revhead
    Revhead
    from Dallas, TX
    Damn, very close to him in Tolar are some people I know could help, but I don't have their number. I'll look for my receipt for when they did the work on my heads.. L&N I think was the name.
  5. Wesley
    Wesley
    bttt since that is the only way I can help at from here.
  6. Revhead
    Revhead
    from Dallas, TX
    this guy is near him.. real nice.. I found this on a drag racing site and if I find his number I'll give casey or rusty a call and give it to him
    2002 0 5.433 124.89 Louis Newlin Cantankerous 355 Chev 23 Model T N/A B/AA Tolar TX Louis Newlin
  7. hotrodladycrusr
    hotrodladycrusr
    Just an update. Casey's pal in Ft Worth, the one he staying with for the weekend, is on his way to pick him up with a trailer. He's sitting on the side of the road still. He thinks he might have everything covered BUT not sure yet. He'll need the axle in the Ft Worth area for replacement.
  8. hotrodladycrusr
    hotrodladycrusr
    Someone in your area would be cool since that is where him and the car are headed.
  9. Wesley
    Wesley
    less than 30 minutes to have the cavalry on the way. the HAMB rises to the occasion again
  10. Rusty
    Rusty
    Got off the phone with Colin. His buddy is on the way like Denise stated. I have found a Maverick Rearend but I have to wait till 4 to get the drivers side axle. It is broke off inside edge of bearing so it is gonna be hard to get out. He will be staying in Keller this weekend. I am sure he is hoping to get it back on the road for the show tomorrow and better yet for the ride home. Yall keep yall ears and eyes open for a rearend close to FT Worth area or some axles.
  11. hotrodladycrusr
    hotrodladycrusr
    Is his first name Casey or Colin??:eek:
  12. flt-blk
    flt-blk
    from IL
    If you can't find an axle let me know and I can look at my yard in Mansfield.
    Worse case I'll pull one out of the Model A so he can get home since I am driving the ElCamino these days anyway.
  13. Rusty
    Rusty
    I just got of the phone wit hStan Hopkins, they say thay got them for $75.00 but they need a length. Anyone know the stock length of a Maverick v8 5 lug rearend drivers side? This is gonna he ahard to get a measurement from before 5pm when they close
    Rusty
    214 537-7423
  14. Slide
    Slide
    According to this:
    http://www.fordmuscle.com/archives/2006/04/9Inch/index.php
    The Maverick rear (if that's what it is) should be 56 1/2" wide axle flange to axle flange. The driver side axle they got was 26-1/8" from the outside of the flange to the end of the axle. If you subtract the difference of the length of the Mustang rear and the Mav rear, you should be looking for an axle that's 25-11/16", right?
  15. flt-blk
    flt-blk
    from IL
    Stan Hopkins rules. He replaced the spider gears in my 8" and recently cut a driveshaft for 67ImpWagon's A coupe.
  16. Casey
    Casey
    thank`s all just got it apart and ron had the right axel !
    how cool is that ? hopefully we will get it back together tonight ?
    it ate up the brake shoes , and ground alot off the bottom of the coil over ouch ! what a ride .
  17. continentaljohn
    continentaljohn
    Great to hear the good news, the HAMB rocks!!
  18. Casey
    Casey
    just did a test burn out! it`s fixed :)
    and I am beat .
    and I am ready for the auto cross :confused:
    tomorow. thank you denise for calling and checking on me !
    and rusty sorry I did not make it to your shop.
    and thank`s to all those that tryed to help !
    now Ill go back to my regular self ! ya wanna race :rolleyes:
  19. hotrodladycrusr
    hotrodladycrusr
    I wanna ride in a couple of weeks;) :D
  20. Anderson
    Anderson
    How in the hell do you break an axle with nothing but a flathead? :p :p
  21. Dirty2
    Dirty2
    I was thinking the same thing ? Must be radial tires on a traditional car ?:eek: :rolleyes: :D
  22. Casey
    Casey
    Ill have to give you a ride my friend ! 300 ? p***es down the track ?racing airplanes at kingsbury ? 4 foot drop off backwards ? I never thought I could do it till today when my rear tire p***ed me :confused:
  23. Casey
    Casey
    hey I wore a flat spot on my new front radials sliding to a stop so they should bounce up and down like bia`s ply`s now .:)
  24. Wasko
    Wasko
    Its posts like this that make proud to be a member of this board. I hope that one day I will have an opportunity to give back to this community in a way of gra***ude for the information, help, and camaraderie. Travis
  25. Frank
    Frank
    I was thinking about this last night trying to figure out what I'd do in the situation. You say the axle broke off just even/behind the bearing? How the heck did you manage to get it out? One way I could figure would be to weld onto the end of the axle stub something you could grip and pull it by some means. That or yank the other side and drive a smaller bar through the gear cluster to pop it out from the rear.
    Do tell. Or pics even.
  26. Casey
    Casey
    well found a new use for a rock digging bar !
    we could not get it out from the d.s. so we pulled the p.s. axel out and nocked it out from the other side, poped right out !
    I will post some pictures when I get home ! hell it`s only friday morning ? it sjust starting !:)
  27. Casey
    Casey
    you got it cookie mama ! :)
  28. Slide
    Slide
    Glad you got back on the road. Lookin' forward to seeing you & your car tomorrow.
