Technical hammer form boot floor help
Discussion in 'The Hokey Ass Message Board' started by haydenrrr, Oct 12, 2015.
  1. haydenrrr
    haydenrrr
    Hi guys,
    The boot floor in my rx3 is rusted out and i am looking at reproducing a new boot floor (not wheel well) with similar patters as the original.
    made a hammer form:
    did a trial on an old sign i had in the shed, was 1mm from memory, hd galved, came out like this
    was very happy, didnt seem to warp much, basically just stood on top of the sheet and went away with my air hammer.
    then i purchased my sheet for the boot, 1500x900x1 zinc annealed, clamped it down and had a go and came out like this..
    absolute **** and am very dissapointed, how do i fix this?? is it because its zinc annealed and isnt as malleable etc? it just warped and looks very very rough
    any help out there?!
  2. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    The first thing I would do is buy or borrow a bead roller. Then get a piece of 18 gauge steel. You'll have a new panel in less than an hour.
  3. haydenrrr
    haydenrrr
    Would be too hard as its a large panel (1500x900) and a wide 'bead'? thats why i opted for a hammer form
  4. Blue One
    Blue One
    from Alberta
    o_O What in the world is a boot floor :confused: :D
    Proper names for what you are working on would help :D
    And, since when is an RX3 a Hamb appropriate topic ?
    1927graham and 56don like this.
  5. Hnstray
    Hnstray
    from Quincy, IL
    I would suggest you NOT use an air hammer for that operation. That may have worked for the sign material as it was likely harder/stiffer than the gal/annealed material.
    I'd recommend you use a blunt metal 'chislel', sort of like some stone masons use, or make one from
    a piece of fine grained hardwood, like hard maple. A 'blade', maybe two inches (50 mm) wide and and handle and flat at the top of that for hammering. The process is called "hammer form", after all :D
    Once you get the hang of it, you can make or modify other tools for specific shapes and contours.
    It will be much easier to control the strike zone and force doing it by hand than with the air hammer.
    Be sure you have the work piece well secured to the form. Clamp it for sure, but also some small locating dowels or screws to keep it from creeping out of position would be a good addition.
    Ray
  6. gimpyshotrods
    gimpyshotrods
    X2. My ***istant and I can fabricate and replace an entire floor pan, from scratch, in the average car, in about 4-hours.
    Bead rollers are where it's at. Even a hopped-up Harbor Freight model will do the trick.
  7. Hnstray
    Hnstray
    from Quincy, IL
    Metal shaping is HAMB friendly. The trunk (boot) floor is no different than the floor in a '30s, '40s or '60s car, when it comes time to replace it.
    Ray
    unkledaddy likes this.
  8. 56don
    56don
    I can't be of any help at all other than to recommend a shoe cobbler to repair your boots.
    Blue One likes this.
  9. Bam.inc
    Bam.inc
    from KS
    RX3? Boot floor? what the ____?
    Seventy-something Mazda? Uhhh.
    Blue One and 56don like this.
  10. Hnstray
    Hnstray
    from Quincy, IL
    Some of you guys must have paid even less attention than I did in English cl***. The RX3 is not the subject of this thread inquiry. The metal forming technique is the subject. But I suspect you already know that..........lighten up. The guy didn't ask for advice about swapping in an R13B.
    Ray
    LOST ANGEL and metlmunchr like this.
  11. unkledaddy
    unkledaddy
    I agree Ray, but the schoolmarms are on the prowl.
    Blue One and Hnstray like this.
  12. haydenrrr
    haydenrrr
    Lol lighten up fellas, i came here for metal work help. Thanks for those that gave some helpful info, will ***ess my options
  13. I for one don't give a rats *** that the car is off topic, if he would have said duece, the idiots complaining would all have stiffys! I'm really surprised that you are having more trouble with Galvanealed than with generic sign material. Are you sure that that truly is annealed, it looks and acts like generic galvanized sheet steel. (Without the annealing process) The Galvanealed that I've used forms almost as good as AK steel. You shouldn't be having the trouble you are with it. Your process looks correct and the air hammer will work if you keep the pressure turned down so you don't over hammer the steel. I use a pneumatic chipping hammer and it works well. Try laying/clamping something rigid and heavy on both sides of the groove you are creating. I-beam would be my choice. Good Luck on your RX3!
  14. john worden
    john worden
    from iowa
    Deep, straight and wide depressions with a hand held hammer or hand tool of any kind will be tricky to say the least.
    No matter what you back up the panel with it will be difficult to accurately guide the hammer. The distortion will be considerable as well.
    A Pullmax type reciprocating nibbler is really the machine for this work.
  15. Crusty Nut
    Crusty Nut
    Damn! He's asking about shaping metal. Mocking him for calling it a boot is about as funny as all the comments about the wrong sided steering wheels down under and other locals.
    Some of you guys need to go back under the rock you came out from under.
    OP- a bead roller will do a much nicer job, but since it is just a boot floor, anything to add rigidity will help keep it strong.
    X38 likes this.
  16. blue 49
    blue 49
    from Iowa
    Here's a pair of wide, flat bottom dies I made for a Harbor Freight bead roller. works pretty good on 20 ga.
    Gary
    gimpyshotrods likes this.
  17. Blue One
    Blue One
    from Alberta
    In order to appreciate humor you need to have a sense of it yourself. In some guys it is lacking. :D
  18. Hnstray
    Hnstray
    from Quincy, IL
    Nice try for a recovery ....but no cigar! It was your last line "And, since when is an RX3 HAMB friendly?" that undermined the 'humor'.........
    Ray
    X38 and Crusty Nut like this.
  19. gimpyshotrods
    gimpyshotrods
    Nice dies. I need to make a set of those, and a double bead set.
  20. Rusty O'Toole
    Rusty O'Toole
    Why don't you use the old sign? Paint it and no one will know.
  21. haydenrrr
    haydenrrr
    wasnt big enough to use lol hmm might try again with the hammerform before making dies..
  22. chopolds
    chopolds
    from howell, nj
    I see one piece of wood you called your hammerform. A true one is 2 pieces, sandwiching the metal in between, and this is what prevents distortion of the flat metal, while you hammer in the shapes. Did you use 2 pieces or just hammer into the channels in the single piece?
    This can be done without a bead roller, but it is far more time consuming!
    Hnstray likes this.
  23. haydenrrr
    haydenrrr
    yep just the single mdf piece. spent long enough on it already so will see how i go doing it a second time and using some better clamps and tooling, dont fancy ****ing around with a bead roller trying to make the sheet fit etc
  24. toreadorxlt
    toreadorxlt
    from Nashua, NH
    you're gonna need a male form on top and really sandwich the metal hard. A bead roller will make a mess of that panel too, unless you pre stretch every bead.
  25. Blue One
    Blue One
    from Alberta
    Undermined or not, the humor was still there.
    No need to recover. :)
  26. X2
  27. Hnstray
    Hnstray
    from Quincy, IL
    There is a another thread currently running...."Tech week emboss your valve cover"..... that contains some good info and tips that may be applicable to your project. Not necessarily the whole process,but some of it, especially chasing of the embossed channels in your floor pan with a 'corking' tool. That is what I was referring to in an earlier post here. In any case, worth a look, IMO.
    Ray
