Hand Bendable Brake Line!
Discussion in 'The Hokey Ass Message Board' started by SlowandLow63, Apr 21, 2007.
  1. SlowandLow63
    SlowandLow63
    from Central NJ
    Not so much, we don't even get ours from Napa. I got wind of this stuff and wanted to p*** the word along to the rest of everyone who might find it useful.
  2. Flathead Youngin'
    Flathead Youngin'
    But wait, there's more! If you order your brake lines in the next 10 minutes, we'll throw in a hot rod in the box for absolutely FREE! That's right FREE! ...or my name isn't Billy Mays
    I would be more interested in this stuff in a coil....like was stated.....
  3. Turbo26T
    Turbo26T
    Just who the Hell is Billy Mays ...and ....why is he yellin' at me to buy some OxyClean !!!???!!
  4. Aman
    Aman
    from Texas
    You could make a cool can in about 5 minutes. Good stuff!
  5. SlowandLow63
    SlowandLow63
    from Central NJ
    This stuff is the Bundy-Flex, makes me think of a dance Al Bundy might do but thats just me. If anybody wants me to score them some PM me and I'll try n help out.
  6. Montechris
    Montechris
    Has anyone used this stuff since the post was created? Is it good stuff? Do you feel comfortable enough to use it with a single master?
    -Chris
  7. butch27
    butch27
    Well: I bought something like that. Kinda greenish black. **** was made in India.
  8. saltflatmatt
    saltflatmatt
    Alliance Vendor
    Used it on my 51 works like a dream.... Yes it is a odd color... Most every auto parts store has it now.
  9. Montechris
    Montechris
    This is great news, I was dreading the idea of doing new brake lines on my car; however they need to be done.
    -Chris
  10. Brad54
    Brad54
    from Atl Ga
    My local AutoZone is selling something that might be the same stuff. It comes in straight lengths, has the dark green (almost black) coating, and it's very soft and easy to bend.
    I did the brake line over the rear axle in my suburban with it, and had to take a couple attempts at it because when I went to flare the end, the flare crushed... first time in years I'd made a flare and it didn't turn out right. Happened on a second flare, too.
    Then about a month later I went to help a friend run new lines on his Fox-body Mustang, and had the same problem making the flares. One of them actually pulled right off the end of the tube. It's a problem I've never had with steel lines.
    Not sure if it's the same stuff as is being discussed here, but it was available at Advance Auto and Autozone. The stuff I used is very easy to bend...almost soft. But I've got good benders, so my problem was not making the crisp tight bends, it was that the line would bend while I was trying to fit it into place--not necessarily at the bend I made, but along the long straight runs. I didn't like the results... but then I get a hard-on when I see nice, professionally bent bright brake and fuel lines.
    I didn't like it.
    -Brad
  11. langy
    langy
    In the U.K. we have Kunifer, Its an alloy of Copper & Nickel, Volvo use it on their production cars. The easiest stuff to bend and flare i've ever seen.
  12. Stick004
    Stick004
    from Missouri
    And to think. I spent all that money on braided steel brake lines... Guess I'm going to reconsider.
  13. Montechris
    Montechris
  14. langy
    langy
    I've only ever seen it in 25ft rolls, It bends so easy i don't even use a bender but just bend it round my index finger. Never had a bad flare with it either.
  15. langy
    langy
    You shouldn't use too much braided either as although it stays constant in section it grows a fair bit in length, Think of it as a water hose pipe.
  16. TagMan
    TagMan
    I went to our local NAPA just before Christmas to buy the Kunifer (90/10, Copper / Nickel) brake line, but the counter guy said they don't sell it any longer, due to the price. He told me a 25' roll would cost around $150, while a 25' of coiled steel cost $25.00.
  17. langy
    langy
    Can't speak for the U.S. but in the U.K. its £17 ($25) per 25ft coil, i think he's overcharging !!! If i posted a roll over to ya it wouldn't be that expensive.
  18. John P
    John P
    from Michigan
    Gentlemen,
    I work for the company that manufactures the dark green colored hand bendable brake lines. Our company is called AGS Company in Muskegon MI and the product that you are referring to is called Poly Armour. This product is the ONLY one on the market that has a polyvinylflourine coating and has 30X the corrosion resistance that standard steel line has. It is easily bent by hand in small radiuses, as well as easily flared with readily available tools. It's available in 3/16", 1/4", 5/16", and 3/8" for brakes, transmission, fuel, and any other hydraulic, air, or fluid transfer lines on a vehicle. Check out our website at www.agscompany.com and take a look for yourself.
    If I can answer any questions, please don't hesitate to contact me.
    Best regards,
    John Peirce
  19. jambottle
    jambottle
    now give us the price for a 25 ft. roll.(retail and hopefully shop discount)
  20. Hi John,
    Very nice product you have here!!
    So are you going to sign up and be an alliance member ?
    Different coatings available? Can we buy direct? catalog available?
  21. Johnny1290
    Johnny1290
    so his website says its available here: sorry for the big size I just copied and pasted
    NATIONAL AGS RETAILERSThe following nationally located retailers carry a limited selection of AGS products. Call ahead for product availability in your area or shop online with some select retailers.
    ACE HARDWARE
    STORE LOCATER
    SHOP ONLINE
    • Specialty Greases (at participating locations)
    <hr> [​IMG]
    STORE LOCATOR
    SHOP ONLINE
    • Poly-Armour Brake Lines and Coils
    • Fittings/***ortments
    • Specialty Greases
    • Gloves (Nitrile & Utility)
    <hr> [​IMG]
    STORE LOCATOR
    • Brake Lines and Coils
    • Specialty Greases
    <hr> [​IMG]
    STORE LOCATOR
    SHOP ONLINE
    • Specialty Greases
    • DOT 5 Silicone Brake Fluid
    <hr> [​IMG]
    SHOP ONLINE
    <hr> [​IMG]
    SHOP ONLINE
    <hr> [​IMG]
    STORE LOCATOR
    • Poly-Armour
    • Specialty Greases
    <hr> TRUE VALUE
    STORE LOCATOR
    <hr> REGIONAL AGS RETAILERS
    The following regionally located retailers carry a limited selection of AGS products. Call ahead for product availability in your area or shop online with some select retailers.
    OHIO
    STORE LOCATOR
    • Specialty Greases
  22. John P
    John P
    from Michigan
    Gentlemen,
    Much thanks to Johnny1290 for posting our product availability and customers where you can find our product. We cover 95% of the aftermarket steel brake lines in the USA. Not all of the customers listed handle the Poly Armour, but our double zinc coated brake lines are equally as easy to bend and flare, but they don't have the green PVF coating. AGS double zinc coated brake lines have 10X the corrosion resistance of standard steel lines, and are available at almost all locations of the list that Johnny posted. They are available in all SAE (domestic) and also in British, European, and Japanese fitments. We also offer 8" adapter lines with different sized fittings on each end to accomodate almost every size and style of master cylinder or proportioning valve.
    Lastly, most of you have been around long enough to know about our chemical and lubricant products. We are the manufacturer of Sil-Glyde Brake Lubricant-#1 in the US, Door-Ease door lubricant stick-our first product since 1937, Lock-Ease graphited lock lubricant fluid, Lith-Ease white lithium grease, Store it-Start it fuel/vehicle storage treatment-the ONLY treatment with octane booster to keep your fuel fresh, as well as many others.
    Thanks again to Johnny, and please don't hesitate to contact us at www.agscompany.com if we can be of any ***istance.
    Best regards,
    John Peirce
  23. John P
    John P
    from Michigan
    Oh, and by the way. The videos on our website under the Education tab, are, in fact, me. Just a small bit of my 15 minutes of fame. I'm not nearly that stoic in real life, but hey, it's what I had to do. :eek:)
    Thanks again,
    John Peirce
  24. Von Rigg Fink
    Von Rigg Fink
    from Garage
    My car-quest guy just quoted 23 bucks for a 25' roll of 3/16..just for an idea of cost
    they called it Poly armor.."the black stuff"
  25. 50merc808
    50merc808
    the "black" brake line from napa works great. we use it all the time to fab. clutch/brake lines.
  26. yellow wagon
    yellow wagon
    from WI
    another +1 for the Napa "black" lines....
  27. John P
    John P
    from Michigan
    Gentlemen,
    NAPA, CarQuest, Autozone, Advance, Pep Boys, O'Reilly, CSK, Murray's, Bumper to Bumper, Auto Value, Parts Plus, PRONTO, Federated, Auto Pride, plus a host of independant store chains and distributors all stock AGS double zinc coated steel tubing and some stock Poly Armour PVC coated steel tubing.
    We at AGS Company thank you for all of your interest, comments, and responses about our products. If I can personally be of any ***istance, please don't hesitate to contact me through the website or this blog. I will certainly get back to you promptly.
    Best regards,
    John Peirce
  28. butch27
    butch27
    On a personal level I didn't have much luck with the greenish stuff- tried to kink and flared off center( and I've done some flaring) One store said it was from India ??
  29. 2afbs
    2afbs
    just found this thread today, luckily in time to do my brake lines. thanks johnP for getting the info out to us. which product do you reccomend for the shade tree mechanics a**** us? also happy your companies products are made in the USA.
  30. Shaggy
    Shaggy
    from Sultan, WA
