Hanging pedals
Discussion in 'The Hokey Ass Message Board' started by coopsdaddy, Dec 21, 2010.
  1. coopsdaddy
    coopsdaddy
    from oklahoma
    Whats the best brake clutch ***em to use on stock 30 ford fiewall(ansen style or kugels that mount completely under the dash)i like the look of the firewall being clean but there high,i like the price of the ones ***us sold(is he still selling)but dont really like the masters on the firewall
  2. turdytoo
    turdytoo
    I'm using a brake only ECI piece. They offer a unit with the clutch master also.
  3. coopsdaddy
    coopsdaddy
    from oklahoma
  4. coopsdaddy
    coopsdaddy
    from oklahoma
    Thinking of going with ansen style,whos making the best one for the money?
  5. Royalshifter
    Royalshifter
    Moderator
    I bought a set from ***us here and they are nice.
  6. The37Kid
    The37Kid
    I'm thinking about swing pedals also, along with cowl steering on my '30 Roadster. Is a '32 Cowl vent a must for filling the master cylinder? That is the one part of the deal that I wonder about. I'm planning on a 1 1/2 - 2 inch rollbar that fits under the cowl that this stuff would mount to.
  7. choppedsled
    choppedsled
    from Spokane WA
    I also am very happy with the unit ***us makes. A simple, clean looking, well built setup.
  8. brigrat
    brigrat
    from Wa.St.
    Maybe ***us will toot his own horn! Got a pic of his? Thanks
  9. I like stuff on my firewall. It's a CAR, and SHOULD look mechanical. Those sideways hidden things scare me. So not user friendly to check and fill if necessary.....my fear is it'd run out of fluid eventually without anyone knowing and cause a wreck. Not on my car
    -Brent- likes this.
  10. 56don
    56don
    ^^x2^^
  11. brigrat
    brigrat
    from Wa.St.
    If your loosing fluid you have "other" problems anyway!
  12. ago
    ago
    from pgh. pa.
    I fab bed my own, rear facing M/C s. used the reseviour with plastic, look up under the dash and see level. fill with squeeze bottle with bent plastic pipe fill.
    Ago
  13. need louvers ?
    need louvers ?
    'Zactly! Hang all that stuff out where you can get at it and where it belongs. Just use cool M/C and such so it's interesting visual clutter... Oh by the way, you can fill one of those silly 90 degree deals with a turkey baster - brake fluid in my armpits - great!
  14. coopsdaddy
    coopsdaddy
    from oklahoma
  15. BOWTIE BROWN
    BOWTIE BROWN
  16. meengrinch
    meengrinch
    from ipswich ma
    this hint may not be for everyone`s taste but i use early corvair master clyinders for both the clutch and brake masters. easy to mount....simple hanging pedal built into the master.......check them out..
  17. coopsdaddy
    coopsdaddy
    from oklahoma
    Im looking for a ansen style pedal ***embly if anybodys got one...
  18. ago
    ago
    from pgh. pa.
    Don't use a turkey baster, use a squeeze bottle with a bent fill. Has a tube that goes to bottom of bottle like a siphon spray gun. gentle squeeze and fluid goes to where you need it. Mcmaster-Carr has them.
    Ago
  19. aaggie
    aaggie
    Check out the roundy round catalogs like Smiley's, they sell pedal ***emblies that are small and light. You might also look at the Welder Series stuff and see if they have a kit that would work. Worst case is buy the master cylinders you need and fab the bracket and pedals.
  20. coopsdaddy
    coopsdaddy
    from oklahoma
    dual pedals,how bought reno rods set up???are they worth a ****
  21. choppedsled
    choppedsled
    from Spokane WA
    Here's a pic of the setup ***us was selling. It's top notch and works with the early Chev pickup master.
  22. buford36
    buford36
    from Maine
    A friend is using the Ansen setup with the chevy dual master cylinder. The master cylinders are 1 1/8 bores and he needs a max of 3/4 " bore to operate the hydraulic throw out bearing. Anyone have a fix for this application? Tom...
  23. metalman
    metalman
    I just set up a pedal ***y for an GM truck master but the cluch cyl was on the right and brake on the left. Had to build a bellcrank type pedal to make it work. Is there a different master then the one I used to be able to use pedals like these?
  24. Deuce Daddy Don
    Deuce Daddy Don
    In 1962, they didn't have all the trick **** like they do today, so about everything was either hand built or used out of a vehicle that you could make do.
    So back then, I used a stock 1960-61 Ford Econoline hyd. brake & clutch swinging pedal setup, works good, easy to work on & ***y. fits under dash to firewall with minimum ease, with both hyd. cyls. mounted on engine side of firewall. Slave cyl. mounts on fabricated plate close to clutch arm.------Don
  25. Clark
    Clark
    Metalman....all you have to do is switch the guts. I think it's the brake side that has a special vavle that the clutch does not. May not be what you wanted to hear after making a bunch of extra stuff.
    Clark
  26. metalman
    metalman
    Yeah, I ***umned the brake side has a residule valve and the clutch doesn't.
    Still wasn't that hard to fit in a bellcrank and it will keep the firewall looking better not having to cross the lines and having people look at the master and see the side labled clutch going to the brakes and vise-versa. They might think I fu-- up when I did the plumbing!
  27. Max Gearhead
    Max Gearhead
    from Wisconsin
  28. Jmountainjr
    Jmountainjr
    Yes. Send the master to Serria Brake and have them sleeve the bore that he will use for the clutch - and if he's using an Ansen style pedal it will be the opposite bore that in the stock pickup - down to whatever size he needs to work with the hyd TO bearing - and move the brake side over to the other bore. The brake setup has the residual valve in it. They did mine and a bunch of others so they know just what you need to do.
    <!-- / message -->
    -Brent- likes this.
  29. Jmountainjr
    Jmountainjr
  30. iammarvin
    iammarvin
    from Tulare, Ca
    Just make some.
      130.1 KB
      138.2 KB
      121.7 KB
    alanp561 likes this.
