Harbor Frieght electric shear
Discussion in 'The Hokey Ass Message Board' started by sfm1951, Jun 29, 2012.
  1. Anybody ever use or buy a Harbor Frieght 18 Gauge shear #92148? Any they any good? Pros or cons. Thanks, Steve
  2. SUHRsc
    SUHRsc
    I have 2 of them with the bluegreen body... not orange... not sure if thats different...
    but they both work great.... one was a friend of mine's and he hooked it to a dimmer switch for house lights... if you slow down the speed... it cuts better on certain materials....
    Zach
  3. b-body-bob
    b-body-bob
    I've got one. That big assed foot on it gets in the way cutting near folded edges. You can't always get the tool where it needs to be. It does cut steel if you can get it to fit where you need it.
    FWIW I'm no fan of electric tools because they can really screw things up if they get off the line. You have to hit the switch and wait until it stops cutting. Seems like I have better control with air tools in that regard, let off the trigger and it'll stop pretty much then and there. That's as much about my lack of skills as it is the nature of the tools though.
    I'm no pro, just a schlub trying to piece an old car back together, so YMMV.
  4. b-body-bob
    b-body-bob
    I might try that with mine, because running at full speed that thing will slice steel like hot butter and it has gotten away from me before
  5. Crazy Legs
    Crazy Legs
    I bought one, works great! It takes a bit of practice to get to cut & spit out the right sized coil otherwise you have to cut.....then bend the coil away from the jaws so you can keep cutting....does that make sense?
    Either way it does a great job!
  6. toreadorxlt
    toreadorxlt
    from Nashua, NH
    I flip mine upside down and clamp it in the vise alot... I don't care what any of the HF haters say.. it cuts equally as good as my friends 40 year old unishear. I did do some custom shaping on the foot to get parts to eject... but for $20, it's a champion. Of of the few good buys there.
  7. flatoutflyin
    flatoutflyin
    I've got a 30 year old Kett Power Shear. Variable speed, worth every penny.
  8. Indychus
    Indychus
    from Irmo, SC
    I have this shear, it took 3 tries to get a good one. The first 2 I got broke right at the cutting end and were not repairable. I returned them each time and they gave me another, no questions asked. The third one has been working fine for 5 years or so now.
  9. Atwater Mike
    Atwater Mike
    DON'T USE a house dimmer switch! (they are designed for lights, not motors. That translates to between 1 and 3 amps vs. the 15+ amps you need)
    Best thing on the planet is an accessory speed control from a sewing machine. It is designed like a pedal for a TiG machine, has about a 6 ft. cord, just wire the 14 gauge leads in series with the machine's power cord.
    Mine came in a blister pack, a bargain at $12.95... I LOVE the foot control. Leaves hands free, just drive with the pedal, and "steer with the rear axle..."
  10. 1971BB427
    1971BB427
    from Oregon
    Must have purchased your's years ago! They're $40 now.
  11. pinupwithgun
    pinupwithgun
    Mine works great! X2 what mike posted.
  12. BadgeZ28
    BadgeZ28
    from Oregon
    I have one. I have gone through two sets of blade/guides for it. Stick with 18 or thinner gauge metal. I would be willing to buy a different brand if I knew the blade and guides would hold up better.
  13. 57JoeFoMoPar
    57JoeFoMoPar
    Great tool. I stepped up and bought a Bosch shear, which was much more than the $40 at HF, but it works great and is a great quality tool.
  14. toreadorxlt
    toreadorxlt
    from Nashua, NH
    I dont go to HF unless its on sale and I have a coupon.
  15. i have the air shear and it works great. like others said it takes some practice
    i dont care what anyone says, HF is really steppin up their game and products. with the 20% cupons in most magazines and sears gettin crappy-er, HF is the best
  16. cagedruss
    cagedruss
    I purchased a second refurbished Milwaukee off of Amazon for $79.99. Came last week and it cuts great and I know it is a quality tool.
  17. Ebbsspeed
    Ebbsspeed
    Published current requirement on the HF site says 1.5 amps required.
  18. Guys I've got a Kett shear. I was thinking this might work better, I want to mount in a frame and bolt to my welding table to make body parts. Do any of you know if the router variable speed control they sell will work to slow it down so I stay on the lines? Thanks, Steve
  19. hoggyrubber
    hoggyrubber
    i haven't got much from harbor freight , but i do have this shear. it works pretty good for the money. haven't used it a ton, but i prob have used it 20 times or so. worth the money already. if it dies now i'm ok with it. someday i will get a nicer one when i find a deal on one.
  20. eldogg
    eldogg
    I've got one on sale and used a coupon. It was cheap $20-25 and works great! It might not live forever in a industrial sheet metal shop but I've had mine for over a year and it aint miss a lick.
  21. 1950Effie
    1950Effie
    from no where
    I have one of their air powered ones. Works pretty good.
  22. krooser
    krooser
    I have a Kett shear that came over on the Mayflower... I think I got it used around 1969 or so. Still works as good as when I got it...
