Technical Hard Anodizing where to get it done
Discussion in 'The Hokey Ass Message Board' started by cb1, Mar 15, 2016.
  1. cb1
    cb1
    from Wisconsin
    Hello,
    Anyone know who can hard anodize aluminum??
    Thnaks,
    cb1
  2. Dean Lowe
    Dean Lowe
    You need a shop that does Mil-Spec plating. In Ca. it's Embee Plating in Santa Ana. In your area, you are going to have to find a shop. Google is your friend.
  3. Jalopy Joker
    Jalopy Joker
    what is hard anodizing used for?
  4. bobss396
    bobss396
  5. bobss396
    bobss396
    Mainly abrasion and corrosion protection, used in military parts quite a bit.
  6. hotroddon
    hotroddon
  7. stimpy
    stimpy
    there is a couple of Anodizers/platers in Manitowoc , and Green bay that do it as they do the parts they use in the big cranes and other stuff from down here ( chicago ) your going to have to google and call them .
  8. dreracecar
    dreracecar
    from so-cal
    Aerodynamic Plating in Gardena Ca.
    They do most of the work for the racing industry
  9. redo32
    redo32
    Whatcha buildin'?
  10. pnevells
    pnevells
    When you look up anodize shops on line , look for Mil-A-8625 type 3 hard coat. Type 3 anodize is different from regular anodize as it is much thicker .001 build up on a surface and it is almost file hard. used in many aerospace, military and medical applications where wear and superior corrosion resistance is needed
  11. cb1
    cb1
    from Wisconsin
    thanks everyone,
    my "how to rebuild a blower" book calls for hard anodizing the rotors and inside of blower case..
    thanks again,
    cb1
  12. tylercrawford
    tylercrawford
    from Buford, GA
    Call around . . . plenty of shops offer it, few do anything other than batch pricing which means you'll pay a flat fee up front whether you have one piece or thousands.
  13. Dean Lowe
    Dean Lowe
    Hard to believe hard anodize is called for on the case. I have never seen anodizing work on castings. Any shop I ever used wouldn't touch castings.
  14. indyjps
    indyjps
  15. cb1
    cb1
    from Wisconsin
    Inside the case and the insides of both front and back bearing plates. And rotors according to the book.
    Supposed to tighten up clearence and protect the surface.
    cb1
  16. cb1
    cb1
    from Wisconsin
    My nephew in law used to work for a fire truck builder in Green Bay area, maybe I will ask him...
    Thanks,
    cb1
