HARD BRAKES
Discussion in 'Off Topic Hot Rods & Customs' started by Sandra K strouse, Jul 23, 2024.
  1. Sandra K strouse
    Sandra K strouse
    HEY GUYS I BOUGHT A C CAB, AND IT IS HARD TO STOP FAST, I PUSH IN ON THE BRAKE AND I HAVE TO USE ALL MY MIGHT TO GET THE CAR TO STOP.
    EXAMPLE I WAS DRIVING ONE DAY AND A CAR PULLED RIGHT IN FRONT OF ME AND STOPPED I PUSHED IN THE BRAKE AND I BARELY AVOIDED REAR ENDING HER. IS THERE ANYTHING I CAN DO TO FIX THIS TO BE ABLE TO STOP IF THERE IS A ISSUE???
  2. JohnLewis
    JohnLewis
    Does it have a brake booster?
  3. Wanderlust
    Wanderlust
    Changing the pedal ratio will help if you’ve no brake booster
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Why the yelling?
    Harder for me to read also.
    More description or photo of set up, maybe
    Ooh yeah,, Nice Truck.
    :D
  5. Mr48chev
    There are several factors that could contribute to that.
    AS Wanderlust said, Pedal ratio is one, Pedal ratio = the amount of leverage you are able to use and T buckets normally have pretty short pedal arms.
    The composition of the brake lining/pads can contribute to it. Certain brake lining material require more pressure to stop.
    The size of the piston in the master cylinder compared to the size/volume of the calipers or wheel cylinders are often an issue if the builder gets it wrong.
    The car looks pretty standard issue T bucket kit ch***is wise. Meaning that there are a lot of T buckets floating around with very similar ch***is under them. There may be some upgrades brake wise that can make things a lot better stopping wise.
    rockable and Tow Truck Tom like this.
  6. How much brake pedal travel do you have? If the pedal gets hard within a couple inches of travel (and you have room/clearance for more travel) the problem might be too large of a bore in the Master Cylinder, which diminishes the amount of pressure you are producing. A smaller bore with more travel (to still provide the needed volume to the wheel cylinders) might be the answer.
    You may also have hard pads/shoes, which some people use to get longer life, but they lack the friction during normal driving to meet everyday needs.
    Good luck
    Tow Truck Tom likes this.
  7. gimpyshotrods
    gimpyshotrods
    Post a picture of the front calipers, the brake pedal, and the master cylinder.
    We're going to need to see what parts are in this.
    Look at all of the rigid brake plumbing and make sure that nothing has been pinched.
    Look at all of the flexible brake hoses and make sure that none appear swollen, cracked, or otherwise damaged.
    Jack up one wheel at a time. Have a helper spin it. When it is spinning, stomp on the brake pedal.
    Let us know what happens.
    Aside from the Ackerman issue, the car is neat!
    Tow Truck Tom and Pocket Nick like this.
  8. Happydaze
    Happydaze
    Most likely master diameter and / or pedal ratio. What are those numbers?
    Chris
    jimmy six likes this.
  9. mohr hp
    mohr hp
    from Georgia
    Don't drive it until you fix it!
    Tow Truck Tom, Deuces and bobss396 like this.
  10. RmK57
    RmK57
    Could be some obstruction in one of the rubber hoses. I’ve had that happen where the rear brake hose was deteriorated / collapsing and wouldn’t stop the car as it should have.
    tractorguy likes this.
  11. MOONRNR
    MOONRNR
  12. jimmy six
    jimmy six
    No booster…7/8” MC….6 to 1 pedal ratio….= good brakes
