Technical Hard clutch pedal
Discussion in 'Traditional Customs' started by Mikey mike, Aug 27, 2023.
  1. Mikey mike
    Mikey mike
    Hi I’m new to the group. I’m finishing up a engine and trans swap in a 52 merc. I used a 1984 T5 out of a mustang and put a new HD clutch and pressure plate/ hydraulic throw out bearing from Ram clutch.also used a wilwood 3/4” bore master. The clutch pedal is really hard to depress Any ideas on how to soften the pedal? I have no clue how what ever is in that box is but I didn’t put that in . And some how mikey mike was supposed to be mitey mike
  2. Budget36
    Budget36
    May need to remove springs in the PP. HD might be the issue.
    I’d check with the PP manufacturer, let them know what you have and pedal ratio, see what they think.
  3. Happydaze
    Happydaze
    Is the clutch actually working, as in disengaging? If you've not got the measurements and spacers correct the bearing can extend until it reaches the circlip at which point it will be heavy, as in locked solid! But it should hit the fingers long before that occurs.
    If the clutch is working but is just heavy there must be something funky going on as the 3/4" master is the smallest recommended by RAM, this will give the highest pressure and thus lightest pedal. The stroke on the master needs to be a minimum of 1.1" but the wilwood should have this (I don't know this off the top of my head by the way, I've been looking into my setup which is similar, but has a 1" master and is a bit heavier than I would like). As has already been questioned, what's the pedal ratio? And is there sufficient travel to stroke the master the required 1.1" minimum?
    Chris
  4. Mikey mike
    Mikey mike
    The clutch works fine. No slipping no chatter it’s just a harder pedal than I am used to. As far as pedal ratio I don’t know what that is. I’m using the stock pedal ***embly that came with a 52/53 mercury. The clutch begins grabbing about 1/2 way off the floor and is fully engaged in about a1/2”after that. I located the master cylinder as close to center of the hole in the firewall where the old clutch linkage p***ed through and connected an adjustable piece of threaded rod to the stock pedal location. It’s a fairly straight run from pedal linkage to master cylinder. Thanks to Budget 36 and Happydaze for your input.
  5. foxbody mustangs are well known for their super heavy clutches, but if everything is modified that may not matter.
    however your factory pedal set may not be setup for hydraulic so it lacks enough leverage. i only know things about lever and Z bar clutches, so i cant really comment on what is needed to fix that.
    clem likes this.
  6. Happydaze
    Happydaze
    Time to measure that pedal ratio methinks.
    Chris
  7. bobss396
    bobss396
    Pictures, we like pictures! My slave is an external 7/8", same clutch master. I had messed around with it and mounted the clutch master lower on the pedal arm... almost impossible to work the clutch. It was fine in the OG position. Look at that first.
  8. Mikey mike
    Mikey mike
  9. Mikey mike
    Mikey mike
    OK, just got on the magic book and googled how to measure for pedal ratio. Length of pedal from pivot pt. To center of pedal pad. Divide that by the length of the push rod from pedal to center of master cylinder piston and that number will be my ratio. 6 to 1 is what I should want to end up with. Thanks guys ,I’ll let you know how I make out and try to post some pictures. Mike
  10. pirate
    pirate
    from Alabama
    Friend of mine had an old Chevy he paid to have converted from an automatic to manual. They used a Wilwood master cylinder for the hydraulic clutch. From day one the clutch pedal was extremely hard to push in. Then one day the the clutch quit working. After dis***embly found the master cylinder bore was scored very bad and fluid was leaking past piston. The culprit ended up being misalignment of the clutch pedal pushrod to the master cylinder. It looked straight but there was some funky geometry as the clutch pedal swung through an arc applying an upward pressure on the forward end the pushrod on the piston in the master cylinder’s bore. The fix was finding a clutch pedal ***embly that came stock in the car and going with the stock manual clutch linkage. The guys paid to do the original conversion just took the easiest route proving “if you want it right do it yourself” works great now!
  11. Happydaze
    Happydaze
    That instruction doesn't read quite right to me.
    Length: Pedal pivot to pushrod, over
    Length : pedal pivot to pedal pad.
    6 is a good number. Fingers crossed for you!
    Chris
    X-cpe likes this.
  12. Mikey mike
    Mikey mike
    Chris you are right. Thanks again.
  13. Mr48chev
    Back in the ancient times when they taught you things you could actually use in school we learned about levers and leverage in 3rd or 4th grade. The longer my handle is on this side of the fulcrum the Easier it is to lift the rock on the other side. The pivot pont changes with the pedal and clutch pushrod but the leverage factor doesn't.
    It's been a long time but I remember drivng a couple of those Fox Mustangs when I worked on them in the early 90s and the clutches were a bit stiff. Still if that master cylinder or the slave is just the least bit ****eyed it could cause it to bind up a bit.
    Illustrious Hector and bobss396 like this.
  14. Happydaze
    Happydaze
    While you're under there with your measuring device(s) it's got to be worth checking the clocking of the mechanism too. It's already been mentioned that the pushrod shot into the master needs to be as straight as possible ( thinking rod angularity) but the action around the pedal to pushrod needs to be correct - ish. To get a visualisation of this, consider a clockface and a pendulum from 12 o'clock. The master cylinder is horizontal to (or slightly above) the 6 oclock position, to the left. Without getting into degrees of movement, the swing of the pendulum / pedal wants to be in the 4 o'clock to 8 o'clock region to give the required horizontal stroke. If the start were to be at 6 o'clock ( or later) position, the horizontal movement would be limited and would cease by 9 o'clock, and would also exacerbate the angularity issue. Hope that makes sense. I can't think of a simpler way to explain it in writing.
    Chris
    clem and teach'm like this.
  15. Mikey mike
    Mikey mike
    After taking measurements I see that I have to relocate every thing but the pedal. The stock set up was too low on the pedal. I have to raise the clutch master and move it toward the drivers side because the brake master is in the way. Then weld a bracket to the pedal to line up to the master. Then I’ll have the correct ratio and a straight shot at the master. Hopefully there won’t be any binding. Mike
    bobss396 and sdluck like this.
  16. wheeltramp brian
    wheeltramp brian
    So what ratio did you end up with?
  17. HOTRODPRIMER
    HOTRODPRIMER
    My Model A was like that, my mistake was using a Hayes clutch, the are notorious for being hard to Engauge. HRP
  18. bobss396
    bobss396
    I made a common plate to mount my brake and clutch masters. The 1st two were from 1/4" aluminum plate, too flimsy but looked nifty. The last was from 1/4" steel and is acceptable.
    I also moved the clutch master up when I went back to the OG pedal pivot. I'm running a Zoom 11" diaphragm C30-ish truck clutch.
  19. Mikey mike
    Mikey mike
    When I’m done it should be 6:1 ratio.
  20. wheeltramp brian
    wheeltramp brian
    Not when you're done, what is it when you measured it?
    Happydaze likes this.
  21. TA DAD
    TA DAD
    from NC
    That is what I am waiting to hear also.
  22. Happydaze
    Happydaze
    X3. We need to form an orderly queue (that's a line for US folks) for this interesting and vital information!
    Chris
  23. Mikey mike
    Mikey mike
    6:1
  24. bobss396
    bobss396
    What is that converted to metric? :cool::cool:
    The Shift Wizard and clem like this.
  25. Budget36
    Budget36
    Still 6-1;)
  26. TA DAD
    TA DAD
    from NC
    I'm lost
  27. Budget36
    Budget36
    I believe he’s replying to the current pedals ratio, that some asked about.
    TA DAD likes this.
  28. bobss396
    bobss396
    Humor my good fellows... ratios are ratios no matter what system. I was the kid in 1st grade waiting to learn about upper and lower case NUMBERS...
    427 sleeper and clem like this.
  29. Mikey mike
    Mikey mike
    IMG_0392.jpeg IMG_0393.jpeg IMG_6952.jpeg Ok been away for a while,did some reading and got on with the project. I had to raise
    the master 2-1/2”and 2”toward driver side. I installed a 1/8”steel plate to stiffen things up.when all was said and done I have a nice pedal. I started out with a 2.2:1ratio and ended up with 4.8:1.
    Thanks to all who helped and those that were lost are now found. Mike
  30. Archimedes, leverage means everything :D
    The Shift Wizard likes this.
