Technical Hard clutch pedal
Discussion in 'Traditional Customs' started by Mikey mike, Aug 27, 2023.
  1. wheeltramp brian
    wheeltramp brian
    You should probably put a gusset on that pivot point as it looks pretty thin.
  2. Mikey mike
    Mikey mike
    Yeah I’m keeping an eye on it. Thanks
  3. Happydaze
    Happydaze
    He's a right old screw up!
    Chris
  4. jimmy six
    jimmy six
    Pedal ratios and master cylinder diameters in brake and clutch systems are probably the most misunderstood items many builders miss when designing a system not originally in their cars.
    Also missed are rear wheel cylinders on disc/drum systems where the rear end came from a power brake vehicle and the builder is not wanting vacuum ***ist.
