hard fuel line fitting help
Discussion in 'The Hokey Ass Message Board' started by 53 hemi, Aug 27, 2010.
  1. 53 hemi
    53 hemi
    I'm hoping somebody here can help me out - I'm having difficulty sourcing a part. I need a 90o br*** fitting for 5/16 line. It needs a male on one end and a female on the other. Its going on a rochester 2g which does not have pipe thread, but instead the same thread as the 5/16 hard line fitting. Make sense? Any help would be appreciated. It needs to clear a vintage air cleaner and I can't get a bend tight enough with my bender.
  2. Mat Thrasher
    Mat Thrasher
    They make fittings that would are the carb thread by 1/4 female pipe. Then you could use a 1/4 male pipe by 5/16 flare 90.
  3. badlefihand
    badlefihand
    Check w/some of the pontiac tri power guys-Spotts,Vintage speed etc. Pontiac used 2g's and 5/16 line w/a 90 or 45 degree fitting to carb set uplike you are describing.
  4. jcs64
    jcs64
    not sure where in upstate you are but these guys may have what you want right on the shelf. I just found them this yr and they really helped me out.
    http://www.fmproducts.com/Index.html
