Technical Hard Fuel Line Nut To AN Adapter?
Discussion in 'The Hokey Ass Message Board' started by GMHTP, Jan 5, 2025.
  1. GMHTP
    GMHTP
    Hello all,
    I'm wondering if any of you know of a fitting adapter that just screws on to a hard fuel line nut, instead of cutting the line for a compression fit AN adapter?
    I'm upgrading my built 283 to multi-port EFI this winter. The plan is to replace the smaller fuel line with two Shafer's Classic 3/8 feed and return hard lines to stay NHRA legal, with the last foot as -6 AN PTFE going into a fuel pressure regulator, then to the Pro Flo 4 fuel rail.
    I've never run fuel line before, so the idea of a cutting a hard line and fitting a compression fit adapter is making me nervous, but maybe it shouldn't?
    I already have some Earl's hard line to -6 AN compression adapter fittings in my cart, but am wondering: does an adapter exist with a female 3/8 thread on one end, and male -6 AN on the other, that the hard line nut would just screw into?
    Thank you for your advice.
  2. TA DAD
    TA DAD
    from NC
  3. Jmountainjr
    Jmountainjr
    Flair the hard line. Get an adapter female inverted flair to male AN.
    1971BB427 likes this.
  4. 19Eddy30
    19Eddy30
    from VA
    Yes there is ,
    But , 3/8s "" Thread"" to 6 male?
    Or
    3/8 OD hard line ? to 6 male ?
    & or
    Inverted ?
    The web site with pic above
    Is NPT to Male #6 AN /Jic
    Many options brands
    Parker
    Aeroquip
    Earls
    Red Horse
    Vibrant
    Ext
    Stay away from cheap knock off china
    Fittings Aluminum, steel or brass
    Just Gary likes this.
  5. squirrel
  6. GMHTP
    GMHTP
    Oh wow thank you all for these. Had no idea there were options like this.
    19Eddy30 I need to call Shafer's this week to verify the nut thread type but it's on a standard 3/8 OD fuel line.
    Will keep you all posted, and thanks again.
  7. squirrel
    5window and GMHTP like this.
  8. Ebbsspeed
    Ebbsspeed
    You probably shouldn't mention multi-port EFI on here anymore.
  9. gimpyshotrods
    gimpyshotrods
  10. GMHTP
    GMHTP
    Gotcha, thanks. Did I mention that I've been tuning the hell out of my Edelbrock AVS2's rods and jets lately?
    5window likes this.
  11. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Just shift over to the "Off Topic" thread and it's ok to put EFI questions on there. :)
    GMHTP likes this.
  12. e015475
    e015475
    from Phoenix
    Another option is to take a -6 AN (or JIS) union, cut one of the nipples off and drill to 3/8". Silver solder the tube into the fitting. The first couple of these I did I took to my local hydraulic shop to have done, but finally just asked if I could buy a stick of silver solder and did it myself.
    I don't trust any adapter with orings in it. 37 degree or inverted flare is ok but still with the potential to leak
    GMHTP likes this.
  13. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Honestly, you ought to get a decent 37 degree flaring tool and some AN or JIC (industrial, steel, cheaper) fittings and jus give it a try. Its really pretty easy if you get a good flaring tool. The 37 degree are generally more expensive, but they have a mandrel that moves eccentrically as it flares and helps prevent cracking the tubing. Then you have the ability to do this forever instead of hunting special fittings . If you decide to do that, shop around for the 37 degree flare. Some are real expensive. I have one from Inline Tube that I like but it was somewhat cheaper when I bought it. Amazon has them for $107.95 now. Some reviews say it won't do stainless....I haven't tried that so can't say....but its rated to do stainless. It does nice work on steel and aluminum. May be another brand on Amazon thats cheaper but I know this is a decent one. It has a ratcheting mechanism where others don't.
    Eric David Bru and GMHTP like this.
