hard to steer around corners at low speed?
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 18, 2013.
  1. Tim
    Tim
    from KCMO
    Hey Guys,
    Sitting watching the snow blow past the windows and figured I'd do a little "arm chair" trouble shooting while i wait for spring to show up.
    I have only about a thousand miles on my 46 ford as I only had it running and together for a little over a month before the white stuff showed up but I noticed that at low speed turning corners is a real brute.
    Now I expected the burning forearms in parallel parking type situations but not when turning from a stop sign or turning the corner while driving in a residential area. It's not as bad as a parallel parking situation but your not going to do it with one hand that's for sure.
    At low and high speeds it feels fine and wants to drive straight, and taking the curves found on highways and interstates isn't to bad, I can drive it with two fingers going 65 mph. So I'm wondering could this be some sort of alignment issue? Could it be a slightly bent front axle? a steering box issue?
    I've had plenty of cars with no power steering and none of them ever gave me this sort of situation so I ***ume something is a bit off somewhere
    I've been playing threw possibilities and thought id just google around and post a thread to see if it sounds familiar to any of you
    thanks in advance
    timm
    random info: 1946 ford tudor, ch***is eng split wishbone kit, posie 3 inch drop reverse eye spring, disc brake conversion, 27 inch tall tires up front.
  2. tb33anda3rd
    tb33anda3rd
    i would check the alignment. and tire pressure. what steering box?
  3. steves29
    steves29
    What steering box? Ratio too high?...steering wheel too small?
  4. hoop98
    hoop98
    from Texas
    Reduce the caster will help.
  5. pinkynoegg
    pinkynoegg
    sounds like something might be loose in the system. might check the tie rod ends or if the rod got bent or something wacky like that. an alignment might have something to do with it but Im no expert on those things.
  6. bdynpnt
    bdynpnt
    too much caster maybe ?when you split the wish bone did the mounts lower the rear pivot points .if so this would add caster making it hard to turn but drive really nice
  7. Tim
    Tim
    from KCMO
    It is the stock steering box and the stock steering wheel, how do you adjust the caster on a straight axle car? The split mounts seem to be real close to where it was stock in regards to height, if its lower its gotta be in the range of a half inch?
    I recall looking at that when we installed it and thinking it looked pretty close to were it was previously but i suppose my eyes could have lied
  8. Tim
    Tim
    from KCMO
    oh, and the drag link and tie rod are brand new with new ends and jam nuts. its all straight and tight
  9. henryj1951
    henryj1951
    from USA
    sux city....unhook the hand cuffs from the chain wheel....J/K
    :cool:
  10. tb33anda3rd
    tb33anda3rd
  11. tigman47
    tigman47
    toooo much caster..can u get a death shimmy on a bump? Tooo much caster
  12. alicia-dusty
    alicia-dusty
    Does it still have king pins?
  13. henryj1951
    henryj1951
    from USA
  14. Tim
    Tim
    from KCMO
    stock spindles, stock axle etc so yes it still has king pins.
    I have zero shimmys or shakes fast or slow, even go to fast over rail road tracks and nothing even close to that happens
  15. Tim
    Tim
    from KCMO
    no photos at the moment, its stuffed into a tiny storage garage right now
  16. need louvers ?
    need louvers ?
    What steering wheel ya runnin'?
  17. Tim
    Tim
    from KCMO
    The stock one, as I stated up there a few back . Thanks for the ideas thus far guys :)
  18. need louvers ?
    need louvers ?
    Sorry, missed that! Has the box been rebuilt?I'm thinking if it has that the rebuilder might not have got the end play set correctly on the worm shaft. Get it too tight and it ets real hard to turn. The only other thing I can think of right off the top of my head is bound up king pins.
  19. Dan Timberlake
    Dan Timberlake
    It should turn REAL ez with the front in the air
  20. Tim
    Tim
    from KCMO
    How could I "test" for bound up king pins? Should it make a noise or anything?
    The box has not been rebuilt, I was looking around trying to find info on how your supposed to maintain it as far as tightness, oil, etc. not having a lot of luck with finding that info though.
  21. pinkynoegg
    pinkynoegg
    I agree with this. Throw her up the the air and try to give her a turn. does it do it both ways? you might also put it up on some vehicle dollies and try to turn the wheels again
  22. Tim
    Tim
    from KCMO
    I've had it up in the air and turned it back and forth with no h***le both ways.
  23. The Ackerman theory should be checked. A straight line from the king pins to the center of the rear end should line up with the center of the tie rod end. If this theory is not followed there will be all kinds of steering problems.
    Split radius rods can create problems too. The front axle as will as the rear axle need to be able to rotate in vertical plane like an airplane propeller. Old Fords have the radius rods attach at the center of the car. When they are split and attached to the frame the rotation is limited.
  24. gimpyshotrods
    gimpyshotrods
  25. need louvers ?
    need louvers ?
    These boxes are pretty simple to work with, but if they aren't right they will make stuff tought to steer. Mike Bishop wrote an excellent article on rebuiling one for American Rodder magazine about twenty years ago. There is a quick parphrase of it on page 47 or so of his book on building a traditional Ford hot rod. I think Vern Tardel has published this article again in his how to series little books. The best way I can think of to check for bound king pins would be to drop the drag link, put the front axle on some jack stands and just move the front wheels back and forth by hand. they shouldn't be too hard to move without weight on them. Then, reach in and turn the steering wheel while it's still disconected. it should spin all the way through it's travel with a single finger.
  26. Tim
    Tim
    from KCMO
    Sturgis, the king pins are in the stock location and the wishbone is split but the ends are only about 6 inches apart from each other and located very near the stock location. The wishbone was only split to clear the fat trans pan of the th350.
    It's the ch***is engineering inc kit and though I didn't ask anyone about this specifically none of the people I talked to that used this kit mention any issue like this so I feel like its not the issue. Though you know Ive been wrong before
  27. henryj1951
    henryj1951
    from USA
    Ackerman is affected by many things ie: center link, angle of outer steering arms.
    ok ok google some Ackermann geometry in image.. may be of some help:cool:
    as well as Race Car Vehicle Dynamics book
  28. Tim
    Tim
    from KCMO
    Ok cool looks like its not king pins, I've done both of those things and remember it well. Ill hunt down the book...that I shamefully don't own...and check out the pages you mentioned.
    Thanks guys :)
  29. hron13
    hron13
    from sandy eggo
    personally to me it sounds like the steering in my OT Austin Mini, i have like 8 or 9 degrees of caster and its fine at speed and going straight, but the steering is damn heavy at low speeds. So my guess is alignment, but don't take my word for it.
  30. henryj1951
    henryj1951
    from USA
    here read this
    The Mark Ortiz Automotive
    CH***IS NEWSLETTER
    PRESENTED FREE OF CHARGE
    AS A SERVICE TO THE
    MOTORSPORTS COMMUNITY
    WELCOME
    Mark Ortiz Automotive is a ch***is consulting service primarily serving oval track and road racers.
    This newsletter is a free service intended to benefit racers and enthusiasts by offering useful insights
    into ch***is engineering and answers to questions. Readers may mail questions to: 155 ****el Dr.,
    Kannapolis, NC 28083-8200; submit questions by phone at 704-933-8876; or submit questions by
    e-mail to: mortiz49@earthlink.net. Readers are invited to subscribe to this newsletter by e-mail. Just
    e-mail me and request to be added to the list.
    INS AND OUTS OF TOE AND ACKERMANN
    Your comments regarding Ackermann, or anti-Ackermann, or perhaps why bother with Ackermann,
    would be appreciated. It occurs to me that the more heavily loaded outside front tire must operate at
    a larger slip angle than is possible for the opposite unloaded front while cornering. The result is that
    the lightly loaded tire is pulled sliding across the pavement not doing much work. I ***ume it is
    reasonable to distinguish between the slip angle of a tire which is being deflected by cornering forces
    and one which is sliding. Would it be more efficient to use front roll stiffness to completely unload the
    inside front during hard cornering? Does Ackermann aid turn in? Would anti-Ackermann provide an
    advantage? Is it possible that toe out in combination with anti-Ackermann might be effective? Is the
    turning angle of the front wheels in most hard cornering racing situations so small that Ackermann is
    not a factor? What are your thoughts?
    For the benefit of newbies, Ackermann effect is a property of steering geometry that causes the front
    wheels to toe out as steering angle increases. If the front wheels toe in as steering angle increases,
    that is called negative Ackermann or anti-Ackermann. If the toe angle does not vary with steering
    input, that is zero Ackermann, or parallel steer.
    Ackermann effect must not be considered in isolation. The tires do not know what kind of Ackermann
    properties the steering system has. They only know how much they are toed in or out, at a particular
    instant. How much the wheels are toed in or out at a particular instant depends on a combination of
    Ackermann effect and static toe setting.
    Additionally, there can be toe changes due to bump steer or compliance steer. For simplicity, we will
    disregard these effects here.
    The static setting provides a starting point when the steering is centered, and Ackermann effect adds
    toe-out from there, in a fixed relationship to handwheel (steering wheel) angle.
    Trouble is, the optimal toe angle in terms of tire performance is not a constant, nor does it have a
    fixed relationship to handwheel input. Unless we are prepared to engineer some sort of elaborately
    programmed steer-by-wire system that controls the right and left front wheels independently, we
    cannot obtain optimal geometry for all possible situations. We are stuck with striking a compromise
    for a particular set of conditions.
    The nature of that compromise depends in part on how much extra slip angle we wish to give the
    outside front wheel. One can reasonably argue that the more heavily loaded wheel reaches peak
    cornering force at a greater slip angle than a more lightly loaded one, so the front tires achieve the
    greatest peak cornering force when the outside tire has a greater slip angle than the inner one.
    The questioner asks whether there is a difference between slip angle of a tire that is sliding and slip
    angle of a tire that is not sliding. More precisely, we might talk about a tire that is only partially
    sliding, in the rear portion of the contact patch, and one where sliding is occurring in the entire
    contact patch. There is no difference in the definition of slip angle; it is simply the angular difference
    between the tire's instantaneous direction of travel and its instantaneous direction of aim: the
    difference between its bearing and its heading. However, there is a difference in the effect of adding
    slip angle in the two cases. If the tire is below the slip angle where its lateral force peaks, adding slip
    angle adds lateral force and also adds drag. If the tire is above the slip angle where its lateral force
    peaks, adding slip angle does not add cornering force and indeed probably reduces it. However, up to
    slip angles ***ociated with total loss of control, drag continues to increase as we add slip angle.
    One thing that makes all this a bit complex is that when a tire is near its peak cornering force, lateral
    force greatly exceeds drag force, yet moderate slip angle changes have a fairly small effect on lateral
    force, but a relatively large effect on drag force. This makes it difficult to evaluate the effects of toe
    changes on cornering capability, purely by observing changes in car balance or amount of understeer.
    Drag forces at the tires do not turn the car in the sense of accelerating it laterally, or centripetally
    (toward the center of the turn), but they do tend to steer the car: accelerate it in yaw, or rotate it.
    This means that it is possible to have a case where we are adding moderate amounts of cornering
    force at the front by increasing outside tire slip angle, yet the steering trace and the driver feedback
    may show increased understeer, and the car may be slower! In such a case, we can, at least in
    theory, dial a bit of oversteer in by juggling tire load distribution, and then we may have a slightly
    faster car than we started with. The only way to know is to try this rather than immediately backing
    up on the toe or Ackermann change.
    We have so far been ***uming that what we're after is the highest peak cornering force. We get that if
    both tires are at their optimum slip angle for lateral force at the same time. However, one could also
    make a case for having the tires not peak together, to make breakaway gentler and make the car
    more driver-friendly. This is somewhat ****ogous to the question of whether to tune the engine's
    exhaust and induction systems for the same rpm, to get the highest peak power, or tune them for
    different speeds, to spread the power band.
    Is this complicated enough yet? We're just getting started.
    Suppose we have sufficient information to decide what slip angles we want on the two front tires, or
    what difference we want in their slip angles. Does that allow us to say what our toe-out or toe-in
    should be at a particular instant? Nope. Without knowing the geometry of the car and the turn, and
    without knowing what the rear wheels are doing, we can't even get close.
    For simplicity, let's suppose we don't want any difference in the inside and outside tires' slip angles.
    Let's take a look at what it would take to get that, in various situations.
    Some readers will be familiar with the concept of a turn center. This is the point about which the car's
    center of m*** or c.g. (sometimes approximated as the midpoint of the car's centerline in plan view) is
    instantaneously revolving, as it negotiates the turn. If the car has a constant at***ude angle – that is, if
    it is drifting or sliding a steady amount – all points on the car are moving about the turn center.
    At any given instant, the car has an instantaneous direction of travel, which is always a tangent to its
    path of motion. If the car is traveling in a curved path, that path has an instantaneous radius r. This
    radius is equal to square of the car's instantaneous speed along its instantaneous direction of travel,
    divided by its centripetal acceleration: r = v2/a. In a totally unbanked turn, with the tires sliding only a
    little, these two quan***ies are approximately equal to the car's speed as read by a speedometer or
    wheel speed sensor, and the car's lateral acceleration as measured by an on-board accelerometer. (If
    the turn is banked, or the car is sliding dramatically, these approximations become much poorer.)
    If, in plan or top view, we construct at the c.g. a perpendicular to the car's instantaneous direction of
    travel, and define a point on that line a distance r from the car's center of m*** in the direction of the
    turn, that point is the turn center.
    In the car's frame of reference, the turn center can be anywhere from the rear axle line to well ahead
    of the front axle line. (It could even be behind the rear axle line, if the rear wheels have a negative slip
    angle. This could occur when negotiating a banked turn at low speed. Normally we can ignore this
    case when studying behavior at racing speeds.)
    The simplest situation is a small-radius turn, taken so gently that tire slip angles are negligible. In this
    case, the turn center is on, or very nearly on, the rear axle line in plan view. For zero slip angle at both
    front wheels, the front wheel axes should ideally meet in plan view at the turn center. That implies
    that the front wheels will have substantial toe-out.
    The larger the turn radius, and the larger the rear wheel slip angle, the further forward the turn center
    moves. At some point, the turn center will lie on the front axle line in plan view. In this situation, we
    have equal slip angles on the two front wheels when the toe-out is zero.
    In high-speed, large-radius turns, the turn center is usually ahead of the front axle line. We now have a
    condition where the front wheels need to be toed in for the slip angles to be equal.
    As a broad generalization, the front wheels are steered more in small-radius turns than in large ones,
    and the turn center is further rearward in the car's frame of reference. This argues for having at least
    some Ackermann in the geometry, but it is harder to come up with a general rule to calculate exactly
    how much.
    In high-speed turns, steering inputs are generally very small, and consequently Ackermann effect has
    far less influence than static toe setting. Ackermann has greatest influence in autocross and hillclimb
    cars.
    Does Ackermann aid turn-in? Basically, yes, and so does static toe-out, at least up to a point. Really
    excessive toe-out, whether from static setting or Ackermann, will hurt front grip and the effect will
    reverse, but within a sane range, turn-in will at least feel quicker with some toe-out. This is partly due
    to the early yaw moment from inside front tire drag as the handwheel is first turned.
    Does using anti-Ackermann along with static toe-out make sense? It's certainly done successfully, on
    winged single-seaters on high-speed ovals. Logically, however, it makes more sense to use static
    toe-in with positive Ackermann. This is conventional practice in p***enger cars.
    What about completely unloading the inside front wheel using front roll resistance? Well, it does make
    Ackermann academic, at least during the time that the wheel actually is airborne, and it eliminates
    any concerns about tire drag due to the front tires fighting each other. Unfortunately, in many cases
    using that much front roll resistance will create excessive understeer.
