Technical Hardener into FLAT rustoleum?
Discussion in 'Traditional Hot Rods' started by AGELE55, May 29, 2020.
  1. Rand Man
    Rand Man
    How much enamel paint does take to cover the average old car, say a 53 Ford?
  2. chasracer
    chasracer
    Greatly depends on the mix ratio. If you do a gallon at 1:1 then you have 2 gallons of paint available to shoot, if 2:1 then it's 1.5 gallons. I can say that in the past I shot a '66 Chevelle coupe, had one gallon of lacquer and mixed it 1:1 - I didn't have enough left to fill a Dixie cup, but it was a yellow over grey primer - it took a lot of paint to get coverage. I think most people say the average sized "older" sedan is usually good with a gallon of color.
    Rand Man likes this.
  3. SS327
    SS327
    I used to sell and repair E-Z Go golf carts. Touched up and repainted a lot of frames and other parts (bodies got regular automotive car paints as required). I used Van Sickle, Rustoleum and Valspar with the Valspar or Majic hardeners and some time the 2 mixed together. I also used it in my primers. Not once did I ever have a problem. Mostly used with the satin black or silver, but other colors too. Acetone or naptha to thin. No problems ever.
    oldiron 440 likes this.
  4. Fortunateson
    Fortunateson
    Does any of this stuff have UV protection? I don't feel like applying sunscreen to my car....
  5. chasracer
    chasracer
    Rust doesn't but the hardener is supposed to help. You can also spray clear over rust but if you're doing that might as well BC/CC it to start with.
  6. oldiron 440
    oldiron 440
    A good black alkyd enamel is from your local CAT dealer, flat, low gloss and gloss. I used hardner them all and never had a problem with to much gloss on the flat or low gloss black. Valspar manufactures there paint.
  7. SS327
    SS327
    Valspar also manufactures Van Sickle I believe.
  8. 1971BB427
    1971BB427
    from Oregon
    I've done almost every build using Rustoleum for the frame and inside and outside of the floors for decades. Sometimes gloss black, and sometimes 50/50 mix gloss and flat to get satin. They don't sell gallons of satin anywhere around here, so buying a gallon of gloss and flat gives me what I need. I like the 50/50 mix result, as I think flat is too flat. Sometimes I do just straight gloss, instead of the mix.
    I've pressure washed, and scrubbed my undercarriage on my '37 Austin for over a decade, and it still looks like new underneath.
    GuyW likes this.
  9. 57JoeFoMoPar
    57JoeFoMoPar
    POR15 direct over the metal, light sand, and then Rustoleum Satin over that. The POR15 is so much more durable than any spray bomb, then the satin just finishes off the right color and texture.
