Technical Harmonic balancer
Discussion in 'The Hokey Ass Message Board' started by Bikelessbill, Jan 20, 2024.
  1. DDDenny
    DIAPER?
    theHIGHLANDER likes this.
  2. Fordors
    Fordors
    The SBC high-perf 327’s and 302 used an 8” damper that was 1 11/16” wide and the hi-perf 350’s (Corvette 350 horse and L-82 engines with hydraulic cams and the solid lifter LT-1) used the same damper, but the TDC mark is a different position.
    mad mikey likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yay !!
  4. DDDenny
    And a bolt on timing tab.
  5. twenty8
    twenty8
    And now, just for fun, this........
    "Are you confused about the difference between dampener and damper? You’re not alone. These two words are often used interchangeably, but they actually have distinct meanings in different contexts. In this article, we’ll explore the differences between these two terms and clarify when each one should be used.
    Let’s define the terms. A dampener is a device or material used to reduce or eliminate vibrations, noise, or other unwanted effects. It can be a mechanical component, such as a shock absorber, or a material, such as soundproofing foam. A damper, on the other hand, is a device used to regulate or control the flow of a fluid or gas. It can be a valve, a baffle, or a similar mechanism."
    Sorry.......:rolleyes::rolleyes::rolleyes:
    MCjim and lumpy 63 like this.
  6. X38
    X38
    Pianos and vibraphones have dampers. Generally felt.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Post #35 & #36 , see post #15 .
  8. twenty8
    twenty8
    Yep, and he's absolutely right....... so stop being a smart***.;):D:D:D (Before you go off like a frog in a sock, note the wink and laughs.)
    Don't mind us. We're just havin' a little fun.:)
  9. ClayMart
    ClayMart
    With your bare hands?
    :eek:
  10. X38
    X38
    Come on man, safety first...I wear gloves.
  11. Onemansjunk
    Onemansjunk
    from Modesto,CA
    6B1628B4-41C6-4230-9194-6A4E05B8A60F.jpeg So would the gland nut on the other end of a 1963 VW crankshaft be considered a- “CRANKSHAFT **** PLUG?”
    427 sleeper and theHIGHLANDER like this.
  12. 1971BB427
    1971BB427
    from Oregon
    A "damper" doesn't just control the flow of fluid or gas. Dampers are also used to control the flow of air. All sorts of exhaust and supply fans use dampers.
  13. theHIGHLANDER
    theHIGHLANDER
    ****in love it. The HAMB at it's finest yet again, but this ain't ****. Imagine being on a job when the guy you're supporting asks for a ½ dozen donkey ****s, AND you're supposed to know what they are. 500 bonus points for the 1st who does know. A clue? Another job he told me we had to put a new horse **** on the ********. I have to wonder what they're called now in today's climate...o_O
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    The business end of a concrete ******** . Construction people have colorful vocabularies .
    theHIGHLANDER and 427 sleeper like this.
  15. Rex_A_Lott
    Rex_A_Lott
    And all those fans are connected to the power in a little box called a peckerhead.:)
  16. lumpy 63
    lumpy 63
    We're not allowed to say ****s anymore at work:p
  17. theHIGHLANDER
    theHIGHLANDER
    But what actually is a donkey ****? I'll give ya 200pts...;)
  18. X38
    X38
    A/C ducting. Well, we call it that.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
  20. twenty8
    twenty8
    Isn't air a gas?:confused:o_O:)
    X38 likes this.
  21. theHIGHLANDER
    theHIGHLANDER
    Yer not fkn right. That's not a bad thing, just sayin...
    2OLD2FAST and lumpy 63 like this.
  22. lumpy 63
    lumpy 63
    In before the lock:D
  23. X38
    X38
  24. jaw22w
    jaw22w
    from Indiana
    That's what we called the connector pieces between sections of scaffolding,
  25. theHIGHLANDER
    theHIGHLANDER
    DING! DING! DING! We have us a winner! 500 bonus points! As usual I dunno whatcha gonna do with em but hey...:D
