Has anyone built a Franklin Quickchange?
Discussion in 'The Hokey Ass Message Board' started by modified1927, Apr 16, 2013.
  1. modified1927
    modified1927
    I bought it many years ago and took it apart then, now need to put it back together and lost all my notes about clearances. its a 4:86 R&P with Detroit locker carrier. 31 spline so cut off the tube ends and now have large 9" ends, bearings and axles. any help is greatly appreciated
    Rich
  2. Weasel
    Weasel
    F-r-a-n-k-l-a-n-d
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I've built a few.
    Carrier preload 60 in/lbs. (no seals)
    Pinion preload 20 in/lbs. (rotating new bearings, 10 in/lbs. used)
    Backlash .004"-.006" (no tight spots)
    I like the backlash even tighter, like .002". The one in my shop truck is right @ .000".
    Remember, all the housings are aluminum, almag or magnesium, They will expand at a much faster rate than the differential, giving more backlash.
  4. flamedabone
    flamedabone
    Gearheads is right about the backlash, the aluminum grows as it heats up, so set em on the tight side.
    Frankland is still in bussiness in Pennsylvania and can get you the shim kits and set up bearings. They.also have a catalog with a great tech section that tells you everything you need to know about set up. Setting up a frankland is so easy, even i can do it.
    Good luck, -Abone.
  5. Then you will be walking me through mine!:eek:
  6. modified1927
    modified1927
    Fair enough, and thank you for all the figures and tips I will be contacting them for the book for sure. I have had this for at least 15 years, and built the axle tubes 10 years ago..
    I do mean it thank you
    Rich
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Don't tell everybody. They will not need to buy my book, if it ever gets finished.
  8. modified1927
    modified1927
    Frankland has a very nice website and I ordered stuff today
    Thanks again
  9. Lytles Garage
    Lytles Garage
    Hi; I have abused my Frankland for 12 years. just like a sore pecker,can't beat em !! Chris
