Has anyone ever had to torque something in in/lbs, instead of ft/lbs??
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Nov 27, 2011.
  1. Toby Denham
    Toby Denham
    from Georgia
    Here's another yep answer. I have a ft./lbs. torque wrench and an in./lbs. torque wrench. Although I use the ft./lbs. wrench the most, there're times when you need the in./lbs. wrench.
  2. oldcarfart
    oldcarfart
    Well, OK.............as long as******* was involved! :rolleyes:
    BTW, I prefer my in/lb wrench in 1/4" drive, less tool to fumble with for low value applications.
  3. nofin
    nofin
    from australia
    That one bolt on a caddy 472/500 water pump is where I discovered in/lbs was not a typo...
  4. hotrod_32
    hotrod_32
  5. RAY With
    RAY With
    Like Flying A above I use it in setting rotation torque in rear end pinion settings and all the light torque bolts in engine building. I like the snapon dial torque wrenches and have the calibration checked every couple of years just to be sure.
  6. JohnT
    JohnT
    Can anyone recommend a decent quality inch lb tq wrench?
    like under 100 clams?
    thanks.
  7. Don Lyon
    Don Lyon
    Harbor Freight if you have one nearby, AND before the Flak starts: I own 2, and they are calibrated annualy. (Im an A&P). The calibration rep said the click-stops from HF are MECHANICALLY as good as any. Just don't have a smooth,fine finish. Mine are over 15 years old.
  8. JohnT
    JohnT
    thanks..
    I saw that... but the range is 20-200 inch lb.
    I would like something lower than 20
    but for 20 bucks I might pick it up anyway..
  9. V4F
    V4F
    from middle ca.
    harbor freight has inexpensive inch pound clickers .............
  10. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    for home hobby use HF click wrench in inch pounds is fine & I also have a proto bar ft pound & a craftsman click in ft pounds.
