Customs Has anyone ever seen a "reverse sectioned" custom?
Discussion in 'The Hokey Ass Message Board' started by 19Fordy, Mar 2, 2021.
  1. Hollywood-East
    Hollywood-East
    I'm sorry... I just don't see it...
    Dear ... (Size 12)
    How do you think I'll look in Suzie's size 5 yoga pants... .02
    Irish Mike likes this.
  2. Squablow
    Squablow
    This image is getting really brutalized since I didn't save a copy pre-sectioning, I had to basically undo the section I gave the last finished product, so excuse the crudity, I am not as good at this as some others are, but here you go. Upper is the reverse section and chop, lower is the same roofline but without the sectioning.
    K13 likes this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    Here’s an example. Custom mod, not factory......
    Ray
  4. rudestude
    rudestude
    61SuperMonza and LOST ANGEL like this.
  5. rudestude
    rudestude
    Or going by what is being called a "reversed section" this would be more like a "reversed chop".....???? 1614805663998942357583712592755.jpeg 16148058411001017506984708809241.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
  6. v8flat44
    v8flat44
    Suddenly, i want a 51 Merc soft top........and yes i love the yellow. Males me think of my 58 Vette in Panama Yellow....
  7. stanlow69
    stanlow69
  8. stanlow69
    stanlow69
  9. Blue One
    Blue One
    from Alberta
    o_O No it doesn’t. Cartoonish is a good description.
    X38 and SR100 like this.
  10. raybhotrod
    raybhotrod
    hardly noticeable too much work for little results i like skinny women
  11. 19Fordy
    19Fordy
    Squablow, The idea would be to leave the rocker panels the same height as stock with the "reverse section" added to the doors. That way the rockers wouldn't look like they were worked on. Your yellow Merc looks good.
  12. 19Fordy
    19Fordy
  13. hrdtlrdr
    hrdtlrdr
    Hilton took a 30-31 roadster body and added to it for the GNRS
  14. idk about that one,,,depending on car and what it might be lacking to make it better.
    I add a few inches to the bottom of my Vicky, the cowl is curved tapered from 1” to 2” and straight across the doors and rear 1/4 before the wheel. Visually the results are “appears” to be chopped more than it is and “appears” to be lowered.
    Now alllllll of that came from head scratching how to actually lower the thing by moving the rear wheel arches up. That was WAY too much work.
  15. Magfiend
    Magfiend
    I have a project on paper I've been working on for years - '61 Lincoln convert, 2" added to the height of the body (1 1/2" through the doors, 1/2" through the rockers) to accommodate a BIG engine and keep it, more or less, under the stock hood. Given the Lincoln is a very square, boxy car, I think it could work...
  16. James D
    James D
  17. X38
    X38
  18. rudestude
    rudestude
    I have had this toy car body kicking around in my junk stuff for a while....kind of wondered what was up with the body...by the grill that was in it and body design I figured probably about a 46-8 Chevrolet but the body looked tall,
    Well Hell...now I know , it must of been
    "Reversed Sectioned" and shortened and....Aw hell I was bored...sorry 20210310_024441~2.jpeg
  19. COCONUTS
    COCONUTS
    Like everything else, sometimes it works and sometimes it does not. I wonder what people thought when they saw the first chop top. In my mind (what little that there is) I don't think the this process of "reversed section" will catch on, well maybe not right away.
  20. theHIGHLANDER
    theHIGHLANDER
    Since it's all an illusion there's likely 6 ways to Sunday that'll get ya there. Personally if I wanted to "add volume" to the main body I'd look at moving trim, drop the rocker trim completely perhaps, maybe add a skin to it at most, probably not worry too much about the front and rear. No 'rule' says the front bumper has to be in alignment with the rocker panels so just some tasteful bumper mods would do. Out back a lower skirt would get it done, maybe some almost Bellflowers. I sure as hell wouldn't consider cutting the car and adding to it. It only works on section jobs because you have planes that visually line up even if you remove a couple inches. Adding those inches disturbs that. Maybe I'm rambling, out...
  21. rudestude
    rudestude
    Back in the early days when the custom touch was removing the running boards , a 36 Ford coupe for a example, this was one of the steps in giving the car a lower , taller looking body.
    There were even companies that made frame covers .
    They were added to the lower edge of the body, becoming rocker panels, once the running boards were removed , it covered the frame rails and gave the appearance of a lower ,taller body. 16155687930253184005834837166176.jpeg 16155689083564225447534909070579.jpeg 16155690151193477635013479499064.jpeg 161556893207921157359123137.jpeg 16155689947175268646731224859129.jpeg
  22. Nostrebor
    Nostrebor
    I'm not feeling it. Too much "junk in the trunk".
    It reminds me of the styling cues on the cars in the movie "The Fifth Element" 5e.jpg
  23. James D
    James D
    Good. I did it as a joke.
    -Brent- likes this.
  24. Nostrebor
    Nostrebor
    I ***umed that based on the mooring line.:) I meant more in general, but my post does not say that well.
    Overall I just am not feeling the concept. I'm not super adventurous when it comes to this stuff, so maybe it's just me?
  25. cheezwiz
    cheezwiz
    I "created " rocker panels that rolled under hard because the owner wouldn't let me channel the body down over the frame rails. I think it turned out fine...
  26. Stan Back
    Stan Back
  27. moparboy440
    moparboy440
    from Finland
  28. moparboy440
    moparboy440
    from Finland
  29. Wouldn’t you just buy a Packard or a Hudson?
  30. verde742
    verde742
    Stan Back likes this.
