Has anyone here ran the Duntov 3030?
Discussion in 'The Hokey Ass Message Board' started by BuickBrad, Sep 5, 2012.
  1. Deuces
    Deuces
    I've had 355's that made 450 ponies and I used a Ford Holley 735 cfm carb....
    And it ran like a wet dream...:D:eek:
  2. Deuces
    Deuces
    The cars that came with the 302 were "all" 4-speed cars... I'd never install an auto trans behind a 302....
  3. X77D80
    X77D80
    from New Mexico
    Here is a clip of my OT car with a 30 30 solid. The car has it's "Born with" 302 and factory exhaust.
  4. BuickBrad
    BuickBrad
    from minnesota
    So if i run the Duntov cam with the current set up i have planned out (327,patriot heads, 10.5cr, 750 carb, edelbrock intake, headers) does anyone have a guess what my hp and tq would wind up being? :s
  5. Deuces
    Deuces
    About 350 ponies....
    Give or take a couple...
  6. pitman
    pitman
    C'mon Deuces, give him the 365 to 375 that GM claimed to put out. The headers aren't the usual 15% gain, since the rams horns were already quite good.
  7. ct1932ford
    ct1932ford
    Ran one in a 327 model a roadster back in the 60's. It ran great street or strip. Ran best with AC plugs.
  8. olscrounger
    olscrounger
    good cam for your specs----will pull hard from 25-2800 to 6500 but needs compression to run right--idle will be about 850-900 and vacuum around 13"--nothin sounds better to these old ears than a solid lifter small block. Have an 097 solid cam in my 57 283 FI car and it also sounds great.
  9. OldColt
    OldColt
    Ditto Deuces, My Dad's Non HAMB friendly '68 302 Z/28 idled roughly around 1100 rpm with a lot of valve noise. It came alive about 3000-3500 rpm, and would sing to over 7000 rpm easily. Under 3000 rpm it was out to lunch.
    We swapped the 3.73 gears with 4.56's to get some low speed driveability. Sweet cam I thought for a lighter car with deep gears. In a heavy car with an automatic, it would probably be a dog.
  10. BOBCRMAN
    BOBCRMAN
    from Holly
    I bought a new 1969 Z/28 loaded with options, cloth interior, console, endura bumper, spoilers and hood induction, very heavy car. The 302 with solid lifters .030-.030 was noisy and not all that great in a heavy car, even with 4.10 factory gears.
    I had problems with pushrods breaking thru the stamped rockers. Excessive valve tip wear. At 18,000 miles the rear cam plug fell out of the engine, at speed, out on I-94 and killed the engine.
    I replaced it with a 355, used the original Z/28 bolt on stuff. Used a General Kinetics cam. Much better than that old .030-,030.. Torque to move that 3500 lbs..
  11. F-6Garagerat
    F-6Garagerat
    I have the Howards hydraulic version. Have t started it up yet, this week I hope. I can tell you it's a quality kit.
  12. Deuces
    Deuces
    13 -18% loss in the driveline...;)
  13. Deuces
    Deuces
    Yeah, I remember those..... They were made here in the States at one time....:)
  14. Deuces
    Deuces
    I kept the 3.73's I had in mine and just installed a smaller Holley 650 List # 4777 carb on it to tool around the 'hood with... It had better low end torque with the smaller carb....
  15. finn
    finn
    Put one in a 55 BelAire hardtop back in the early 70's. 283 (of course the guy who sold it to me claimed it was a 327 Corvette engine, (weren't they all?) 3 speed Hurst, 3.73 gears, 4bbl Carter(?) and I can't recall the heads (CRS).
    Sounded great and fun to drive, but not very fast.
    Would I do it again? Yes, without a second thought. Especially if I could be 19 again.
  16. OldColt
    OldColt
    Smart move in my opinion. Those 302's came from the factory with a 780 cfm Holley. Hell, that equals to a 1100 cfm on a 427! I tried a 780 Holley on a high compression cammed up 302 sbf once, and the low end response was terrible. A 600 cfm Holley wound up giving the best strip times, and I ran a 550 Holley on it on the street because it was snappier, and used a little less fuel. I think most of us have started out with the bigger is better mistake on carb sizes (including Chevrolet?).
    --- Steve ---
  17. 70chev
    70chev
    from knox, pa.
    Tried a 30-30 in my '60 Chevy hardtop when in high school, my boss at the gas station where I worked after school installed everything for me, though was less than enthusiastic about the project. 283/2 barrel/3 speed and likely a 3;70 ratio rear was converted to the solid lift 30-30 with an old Chevy 4 barrel intake and a Carter WCFB. It was just 'never right' as I did not have the funds at the time to do the job correctly via rear end ratio, different heads maybe, etc. Sure sounded good though, along with the Walker Continentals....We put it back stock after a short time.
  18. Deuces
    Deuces
    Somehow, I can't imagine all those options added 300 lbs to a 3200 lb car...:confused:
  19. Deuces
    Deuces
    Who sez you had to be 19 to do it all over again????...;):)
  20. Deuces
    Deuces
    How true it is... The L-79 327/350 Vettes and Novas came with a little 575 cfm Holley... Maybe even smaller..
    I do have a GM/Holley 780 from an LS-6 laying around for a future 302 build..;)
  21. Deuces
    Deuces
    Only go a 1/4 turn in from zero lash for the valve ajustment... That should add some more vacuum at idle and snapier performance...
  22. indyjps
    indyjps
    That cam was designed for sustained high rpm, based on available ****ty valvetrain of the time. You can do much better on a cam to get the most out of the patriot heads you spent good money on.
  23. 40fordtudor
    40fordtudor
    that was the earlier cam's settings---the Duntov 94 or 96?? Can't remember----finish the sentence, "****".
  24. Deuces
    Deuces
  25. falcongeorge
    falcongeorge
    from BC
    You've piqued my interest. What intake and whats been done to the heads? How much compression? Send me a pm if you prefer.
  26. McGurk
    McGurk
    from Mid West
    Well this is probably going to ruffle some feathers, but what the heck. The GM 30/30 camshaft is/was the Bubble Gum of camshafts. Yeah it would allow an engine to spin some RPM, but it did not really wake up until the engine was around 4000 RPM and while not having seen an actual dyno chart I think that the HP fell off around 6500 RPM.
    When you compromise camshaft timing in order to facilitate a vacuum brake booster then it cannot be that great of a camshaft.
    McGurk
  27. Here's my friend Simeon's '55 with a Duntov 30/30 grind solid lifter cam.
    He runs it in a 327, camel hump heads that have been ported, with an early Edelbrock Torker Intake and a 650 carb.
    With a four speed and 4.11 posi... he's run a best of 12.40
    Here's a run where he ripped off a 12.60
    It's all period parts... and it runs!
    <iframe width="560" height="315" src="//www.youtube.com/embed/8JKYSL2BCi8" frameborder="0" allowfullscreen></iframe>
  28. Charlie Fernandes
    Charlie Fernandes
    from Ceres, CA
    25 years ago I bought a 62 Corvette that was an original fuel injected 365hp car. The guy put a 4 barrel on it because he couldn't get the engine to run good with fuel injection. As it tuned out he had rebuilt the engine and added an aftermarket cam that had a lot of valve overlap. As soon as I put a new 30-30 OEM Chev cam in it the fuel injection ran fine 27sedanratrod
  29. falcongeorge
    falcongeorge
    from BC
    A Torker is period all right, if you consider mid seventies "period". It sure isn't mid-sixties "period", if thats whats being implied here, I'm not saying thats Sams intent, but thats how it will be taken, and I am not gonna silently stand by while history is being re-written. I was there, I sold this stuff.
  30. rfraze
    rfraze
    I have not read all the posts, so forgive a repeat, if I warn about not forgetting to put a zinc additive in the oil before starting up an engine with a flat tappet cam. Most know by now of the removal of that additive from oils. Make sure your oil has zinc or prepare to buy another new cam sooner than you wanted.
