Has Anyone put a Deuce on an A frame?
Discussion in 'The Hokey Ass Message Board' started by 1beatnik, Jun 24, 2013.
  1. 1beatnik
    1beatnik
    from indiana
    Just got a wacky idea to take my A body off and install a 32 on my ch***is. My question is I have a stock wheel to wheel A frame length can the rear fenderwell of a 32 line up. If possible post any pics or post a length of you 32 from front of cowl to rear axle centerline.
  2. 19-c
    19-c
    I hate to be a buzz kill but why?? I know you already have the model A frame, but honestly I am not sure that the modifications needed to do the swap are worth it. If it is because of $$$ then save for a 32 frame and do it right. I think you would be much happier. There is a way to do anything you can dream up, however that doesn't always mean it should be done. Just my humble 2 cents
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    Isn't a Model A wheelbase 103.5"?...Deuce is 106"...
    kidcampbell71 likes this.
  4. gwhite
    gwhite
    SUPER MODERATOR
    Put down the beer and walk away...a full fender '32 will look goofy on an A ch***is, as the 32 frame is thicker vertically and is stamped in place of running board aprons. A ch***is would require A aprons which would look out of place IMO. The bulk of a fenderless '32 body will overpower the skinny side profile of an A ch***is.
  5. Danny G
    Danny G
    When I was 12 I bought a 32 3 window on a 29 frame. The rear wheels were in front of the wheel wells and it drove like a big go kart. the car was channeled and the engine sat back under the cowl. The guy I bought it from put his roadster body on the 32 frame and sold me what was left.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Not a good idea for all the reasons mentioned. That 2 1/2 inches of wb makes a lot of difference in both room for things and proportions. It will not look good at all or work well at all.
    Don
  7. That would be like putting a SUV body on a Miata ch***is!!
    Doc.
  8. Mr48chev
    I'd have to believe your first sentence says it all. To quote: I got a WACKY idea to take my A body off and install a 32 on my ch***is.
    And unfortunately you aren't even the first to bring it up.
    Some things just don't work no matter how long it takes to save up the coin to do it right and this is one of them.
  9. Been done. Looks like ****. Don't do it.
  10. Garry Carter
    Garry Carter
    What 3WLarry said ... wheel bases are different and the added work to do this kinda swap simply ain't worth it. Besides, it would look like ****, as has already been noted as well.
  11. texasred
    texasred
    from Houston
    Get back on your meds, you will be better in a few days...
  12. Hackerbilt
    Hackerbilt
    When you think about it...Model A's themselves look better on a Deuce ch***is!
  13. 3wLarry
    3wLarry
    from Owasso, Ok
    this was actually what I was thinking when I first posted...but I got all PC...:D
  14. Bruce Lancaster
    Bruce Lancaster
    Not a good idea...the WB can be handled but support for body would take major engineering to have any real strength, and the whole lash-up would be essentially a full size car built like a T-bucket.
    Without radical frame reconstruction...if you do that, you might just as well simply build a square tube frame of suitable size...yo can stretch the A wheelbase by using V8 rear and spring mounts backward on axle. This will give you a bit too much, so jack around front crossmember or use '35 front end, get it so you have proportional front length and engine compartment is not in the p***enger compartment.
    Obviously fenders aren't going to be in the mix...A frame againdt stock '32 floor would look essentially like a channeled car.
    Result will be a car that will have all onlookers itching to take it apart and use frame and body separately to build more reasonable and functional vehicles...
  15. HOTRODPRIMER
    HOTRODPRIMER
  16. Rickybop
    Rickybop
    That would be tacky...hacky...**** sacky. Step backy from the wacky tabacky.
  17. tfeverfred
    tfeverfred
    It'll go on a S-10.
  18. You can put Granny ******* on a stripper if you want.
    Might even talk Granny into going ******* with a thong and high heels.
  19. hotrod40coupe
    hotrod40coupe
    With an idea like that, you should run for Congress.
  20. bgaro
    bgaro
    the easy way out isn't often the best. use the cross members on 32 rails, what you got for axles?
  21. Rickybop
    Rickybop
    You're being PC and I'm being a smart***. Did we switch to an alternative universe?
  22. falcongeorge
    falcongeorge
    from BC
    This!:p
  23. HomemadeHardtop57
    HomemadeHardtop57
  24. ronnieroadster
    ronnieroadster
    Two words ---- DONT DO IT----- oh **** thats three words!
  25. Bruce Lancaster
    Bruce Lancaster
    On the other hand,...hmmm. There isn't any other hand.
    Let's leave it like this...you get near a deuce body, we'll all come out there and kill you, OK??
  26. HOTRODPRIMER
    HOTRODPRIMER
    DON'T PISS OFF BRUCE :D HRP
  27. classic gary
    classic gary
    Don't listen to them, I'll trade you my A ch***is for your '32 ch***is!
  28. uncle buck
    uncle buck
    what the hell you been smoking?
  29. steel rebel
    steel rebel
    Looks like the Pickers 32 in put on an A frame.
  30. 3wLarry
    3wLarry
    from Owasso, Ok
    No, I'm just getting old and you're going thru your second childhood...:)
