Has anyone (rear center section)
Discussion in 'The Hokey Ass Message Board' started by Stitch, Jun 9, 2006.
  1. Stitch
    Stitch
    Heard this a few years back!!!
    Has anyone... every installed a 9 3/8" center section with a 2.50 gear from a late 60's Mercury Convertible into a 9" Ford 31 spline rear housing.
    Will it work?... and ... Are the yokes the same?
    If so does anyone have one I can buy.
    Thanks in advance.
  2. jetmek
    jetmek
    dont know about the 250 gears,but i had one that was 3 or 3 1/4 to 1 and the ring gear would not clear the opening in the housing. it was 28 spline btw
  3. Crusty Nut
    Crusty Nut
    A 9 and 3/8th housing has a small area on the mounting flange clearanced out for the ring gear to slip past when installing. A nine inch housing can be clearanced to fit, it would take a grinder and about 5 minutes.
  4. I installed a 68 Merc wagon 28 spline 9 3/8" diff in my 32's early 60's pickup rear axle housing.
    Dropped right in.
    2.75 ratio.
    What you have to watch is companion flange length.
    When I went to a 9" diff with 3.70 gears I had to make a new driveshaft due to the 9 3/8" companion flange was 1" longer than the 9" companion flange.
    Sorta wasted a nicely built and balanced driveshaft, but I hung onto it and after it gets cut 1" it'll go into the 31.
