Technical Has anyone soda blasted an aluminum intake?
Discussion in 'The Hokey Ass Message Board' started by KoolKat-57, Dec 20, 2016.
  1. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I have an aluminum dual quad manifold that has been painted.
    I really would like to remove the paint.
    I have searched and found many ideas for cleaning the paint off of aluminum intake manifolds.
    I did not see soda blasting as one of the ways to get the paint off the manifold.
    It seems to me that it would do a great job, and leave the surface like almost new.
    What do you think?
    KK
  2. theHIGHLANDER
    theHIGHLANDER
    It will depend upon what was done to make it hold paint, and maybe why as well:eek: You could try liquid stripper, sure to be a mess but might pull any old stains out too. In order to look 'new' again I've seen shot peened intakes. Gives it that shiney hard surface but gotta find a competent shop to do it.
  3. jimmy six
    jimmy six
    Get the paint off first. Soda leaves the aluminum really nice. I do carb bodies with it.
  4. TagMan
    TagMan
    Fresh gl*** beads @ 40psi works great.
    Deuces likes this.
  5. Willy_P
    Willy_P
  6. I use fine gl*** beads @ 40 psi or lower and the parts come out great.
    I restore vintage snowmobiles as well and many parts are aluminum. My preference in cleaning aluminum. I have tried baking soda or sodium bicarbonate and was not real impressed with the results.
    Vic
  7. mad mikey
    mad mikey
    Gl*** beads, I have done lots of intakes that way, they look like new when done.
    Deuces likes this.
  8. Mike VV
    Mike VV
    from SoCal
    Actually, "any" type of blasting will leave the aluminum looking sort of white(ish).
    It will also be MUCH more susceptible to stains with the original factory pouring "closed surface" opened up and /or the original coating (if used) removed . A little more work to remove fuel and dirt/oil stains.
    Mike
  9. D.N.D.
    D.N.D.
    Hi Kool
    Maybe get some 1/8 alum sheet and make up a few test strips, see if the blaster will make a sample for you from each media
    Than you will know what your manifold will look like, be sure to mark them so you know what is what
    You can also Tumble it to for a smoother surface and ball burnish to be more shiny
    DND
  10. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Thanks guys, all good suggestions!
    KK
  11. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Had it done last year, still looks great, $40 and about an hours time!
    Quick, neat, and at a reasonable price.
    KK
    Deuces and j-jock like this.
  12. 1ton
    1ton
    So do you guys leave it as blasted or do you seal it with something before it gets mounted?
  13. plym_46
    plym_46
    from central NY
  14. primed34
    primed34
    I just put mine back on the engine.
  15. Joe H
    Joe H
    I used soda on part of a radiator, came out clean and smooth. Baking soda kills gr***, I found out after a couple days when a big brown spot started showing up!
