Projects Have a quick question about seam sealer
Discussion in 'The Hokey Ass Message Board' started by Overdrivex, Apr 13, 2020.
  1. Overdrivex
    Overdrivex
    Is seam sealer meant to only be used inside of a car, or can seam sealer be used on the outside as well? I would like to use it to seal up the edge of a quarter panel at the bottom of the wheel well, but I'm worried about if it will hold up. Looking at the 3M Urethane Seam Sealer which says its for interior/exterior work or the Eastwood Seam Sealer in a caulking cartridge.
  2. Seam sealer can be used inside and out
    CobraJoe likes this.
  3. southcross2631
    southcross2631
    I have seen people use it on leaky windshields. so yeah go ahead.
  4. oldiron 440
    oldiron 440
    I personally like 3m two part seam sealer, it's expensive but it's the best....
  5. OLDSMAN
    OLDSMAN
    A two part seam sealer is the best, as said it’s expensive but will do a much better job
  6. Overdrivex
    Overdrivex
    I'll get some of the two part seam sealer then since the consensus is that it will do a better job. Thanks!
  7. loveoftiki
    loveoftiki
    from Livonia,Mi
    Make sure ya ask for the inexpensive gun too..PN 08571
  8. Crest brand seam sealer is amazing. I highly recommend it. Used by Mercedes body shops I know of.
  9. manyolcars
    manyolcars
    I guess you meant that as humor. On ebay that gun is $60 to $100
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
    Yep...most people buying that and using it are earning a living using...
    s55mercury66 and gimpyshotrods like this.
  11. nunattax
    nunattax
    TIGER SEAL is great stuff reasonably priced.
    Bill's Auto Works likes this.
  12. Dirk35
    Dirk35
    Like the other guys said, seam sealer is for both inside and outside. Go look in the back of any pickup bed after about 1960, you'll see the seam sealer and how the factory applied it. Then it just gets painted over.
    Desoto291Hemi likes this.
  13. Overdrivex
    Overdrivex
    Thanks guys! Looks like I should be okay to use the seam sealer then. So I should use two part sealer, as mentioned before for best results then?
  14. Flathead Dave
    Flathead Dave
    from So. Cal.
    What does the label say?
  15. el Scotto
    el Scotto
    from Tracy, CA
    Two words: Expanding Foam :D
  16. Overdrivex
    Overdrivex
    I've got another quick question. I found something called 3M Cavity Wax Plus. I was thinking of applying that after using some Eastwood Internal Frame Coating. My question is, how often will I have to recoat with the cavity wax to keep everything protected? Would you guys recommend Fluid Film instead of the 3M stuff?
  17. Stu D Baker
    Stu D Baker
    from Illinois
    Cavity Wax is an oily/wax mixture that is meant for inner panels and panels that are boxed in with little access. It works well. Once you apply it, it's there. Good stuff.
    Bugguts likes this.
  18. Overdrivex
    Overdrivex
    Thanks! Is there a specific type/brand you recommend? Seems like a lot of people recommend Fluid Film based on my research.
  19. ol'stinky
    ol'stinky
    from New Jersey
    It can be used both inside and out. Some hold their shape, and some flow more. Also when buying it, consider if it can go over bare metal, some are made to go over sanded primer. I work in a body shop, there are 1000 different seam sealers depending on what you want to do.
  20. Overdrivex
    Overdrivex
    Awesome thanks! Do you have any experience on how Fluid Film reacts with seam sealer? I just don't want to apply fluid film and then have my seam sealer coming right off.
  21. ol'stinky
    ol'stinky
    from New Jersey
    Isn't Fluid film a corrosion protection / cavity wax type product? I would ***ume it it's already applied, you will need to thoroughly clean and degrease the area before applying seam sealer.
  22. We use the 3m 8852 cavity wax at work. I apply it any time a door is opened...new outer panel, repairs to existing panel, or salvage door shell. Once it's in there, it's in there
    I prefer two-part sealers, they're epoxy based.
    Urethane sometimes get used in visible areas where it is factory-applied after e-coating, typically in late-model import car trunk areas.
  23. Overdrivex
    Overdrivex
    I would probably apply the seam sealer before using Fluid Film. My concern is once the Fluid Film is on, I'm sure that some may come in contact with the seam sealer, so I just don't want it to loosen the sealer.
    Awesome thanks! I looked at the 3M cavity wax, but it is quite a bit more expensive. Do you think its worth the extra cost over fluid film? I would be buying the aerosol cans if that makes any kind of a difference.
    Are two-part sealers easy to work with? My worry is that one of the seams I have to seal I will be applying it vertically...so I just don't want it to be hard to work with and dripping all over me.
  24. abe lugo
    abe lugo
    make sure your seal sealer or whatever you decide to use is 100% done drying and hard before applying paint. You don't want to have something soft and kicking under primer.
  25. Fortunateson
    Fortunateson
    For cavity wax I've used WaxOyl, I believe it's made in Britain. Excellent product and reasonable price, especially factoring in th epeace of mind it brings.
  26. Pats55
    Pats55
    from NJ
    Waxoyl, fluid film, cavity wax, Inner panel protector are all calcium sulfonate coatings. This is the active ingredient in undercoating. A lot of these coatings use waxes and oils. Principal behind this type of calcium sulfonate are millions of platelets that block the oxygen. Are all good products. I usually in cavities I treat first with Phosphoric Acid then the Permanent Rust Sealer primer and then I'll spray the calcium sulfonate in. As Remo says Why take a chance?
    32SEDAN likes this.
  27. Stu D Baker
    Stu D Baker
    from Illinois
    Couple of important things to remember. Seam sealer should be used BEFORE cavity wax. 3m brand is pricey $$, but for the most part, 3m has quality products. Other brands can be fine, if they are equivalent to more costly products. In your situation, if I understand correctly, the product will be used on your own car, and you hopefully don't want to have product issues. That said, maybe spending a bit more $$ (not like this is an ongoing expense for your project) would be more in line with your long term goal of preserving the car as best you can. JMHO, and good luck.
    The37Kid likes this.
  28. Overdrivex
    Overdrivex
    Thank you everyone! I will probably use the 3M products then since I want this done right and don't want to have issues down the road.
  29. nunattax
    nunattax
    .great tack no connection to u pol
  30. Overdrivex
    Overdrivex
    That looks pretty good! However, most here seem to recommend a 2 part sealer rather than one that comes in a tube that you use in a caulk gun.
    Another note, after applying seam sealer on top of epoxy primer, can I put high build primer over it before painting? My process was going to be:
    1.) Epoxy Primer
    2.) Body Filler
    3.) Seam Sealer (is this when I should seam seal?)
    4.) Epoxy Primer
    5.) High Build Primer
    6.) Topcoat
    7.) Clearcoat
    8.) Cavity Wax/Fluid Film etc.
