Technical Having a power steering problem.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Jan 20, 2025.
  1. wheeltramp brian
    wheeltramp brian
    On my 64 el camino the power steering pump And box Have been leaking for a very long time. I bought
    A new steering box and pump from opgi. The box Is advertised as a modern feel box and is a little quicker ratio. I've installed this box on other customers Cars, and it's pretty nice. The problem I'm having is
    When I get in And fire the car up the power steering does not work But after trying to turn the wheel really hard It finally kicks in, but it's hard to turn like very little assist. The box itself is a new delphi , but the pump is remanufactured. Does this sound like anything familiar as in the box is bad or the pump's not putting pressure out? Being that i replaced both at the same time I don't know which one's bad.any thoughts?
  2. Bandit Billy
    Bandit Billy
    I have a 442 with PS and years ago I had a box go out and replaced it and rebuilt the pump while I was at it. The new stuff sucks! I took the pump apart twice, added a filter in line, bled it 100 times before figuring out it was the box. I went through 3 off the shelf units before I bought a Red Head box. Like I said, that was years ago and still working fine.
    dana barlow likes this.
  3. wheeltramp brian
    wheeltramp brian
    That's the reason I went with the new box Because all the parts store boxes that I've put In other people's cars including mine i had had to replace because they were either loose or leaked.
    Bandit Billy likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Had an original box that started leaking real bad but worked fine. Went to the bone yard and pulled one. That one did exactly what you described. So I’m going it’s the box.
  5. wheeltramp brian
    wheeltramp brian
    Man, that would suck if it's the box cause that thing was expensive and I bought it about a year ago. So I'm sure there's no warranty.
  6. wheeltramp brian
    wheeltramp brian
    Hmmm...Is that the valve that comes out of the back of the pump?
  7. Kerrynzl
    Kerrynzl
  8. wheeltramp brian
    wheeltramp brian
    Okay, thanks. I could easily swap that out with my old pump.
  9. Pav8427
    Pav8427
    Similar results when I swapped box and pump for remanned units on my OT H/O.
    Ended up removing valve from back of pump and reinstalling. Turns out rebuilt and even new can have some junk in them and once I put that valve back in it works like a charm.
  10. wheeltramp brian
    wheeltramp brian
    I'll try the valve today. That's the easiest thing. Hopefully I didn't toss the old pump
  11. jaracer
    jaracer
    Make up a line to "T" in a pressure gauge. With the engine running at least 800 rpm, turn the wheel. You should see and immediate rise in pressure. With the steering hard left or hard right, pull hard on the wheel, the pressure gauge should read at least 1000 psi. That will tell you if the problem is the pump or the box.
  12. wheeltramp brian
    wheeltramp brian
    I swapped out the valve and no change. When I look in the pump I don't see any fluid moving so I think the pump is bad. Usually when you fire it up and it's low You could see fluid moving around pretty good. When I fired this one up The level just went down slowly.
  13. In_The_Pink
    In_The_Pink
  14. wheeltramp brian
    wheeltramp brian
    Being that I didn't see any fluid moving I got another rebuilt pump from the parts store. It all worked Out and the steering is good again. The steering is easy and it hasn't been hard at first start yet. We will see in the morning when it's 25° out what it does.
    Johnny Gee likes this.
  15. wheeltramp brian
    wheeltramp brian
    Well this morning, the steering didn't work for a minute so I believe the box is bad.lame
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
  17. jaracer
    jaracer
    If it is really cold and you have a vane type pump, that could be normal. The vane type pumps rely on centrifugal force to move the vanes out. When the fluid is very cold it takes a bit for them to come in contact with the housing and begin pumping. I lived in Illinois and on really cold winter days every 60's model Ford product did this.
    Mr48chev likes this.
  18. wheeltramp brian
    wheeltramp brian
    It's a 60,s gm pump
  19. KenC
    KenC
    I think a full synthetic fluid would be worth a try. Flows easier when cold
  20. wheeltramp brian
    wheeltramp brian
    If feel the synthetic isn't gonna fix the problem as it was fine before with the old parts
  21. jaracer
    jaracer
    I believe the GM pump is also a vane pump. See #13 in the image vane pump.jpg
  22. Mr48chev
    All of the early with a can Saginaw pumps are vane pumps. Reseal kits for them aren't spendy and they aren't hard to rebuild. The vanes could be sticking in the rotor though.
    On a used pump that doesn't work right and makes noise normally the pressure plate and Trust plate 11 and 16 get alled from the rotor and vanes spinnning against them when the pump runs dry. vane pump.jpg
