Technical Head gasket installation, opinions mine and yours
Discussion in 'The Hokey Ass Message Board' started by theHIGHLANDER, Dec 9, 2024.
  1. theHIGHLANDER
    theHIGHLANDER
    Ok, ALUMINUM HEAD and IRON BLOCK straight 8. The new head gasket is dead soft copper one side, composition and copper seal rings on the other. My brain is saying seal the cylinders at the block with the comp/sealing ring side to the iron. Let the aluminum crush seal against the all copper side. When you O-ring an engine for boost or high compression you put em in the block, I'm using that thinking I suppose. I also plan to copper hi-temp spray the block side of the gasket but not the head side. The copper spray isnt 100% but "feels like" a good idea. Old motor obviously being a straight 8. The engine is fresh, just an error in initial installation requires a new head gasket. Its an Auburn 8, as I know some will ask. No, pictures not happening just yet. No, I didn't do the 1st install. That's all the evidence your honors, what say you. And as always thanks in advance.
    Sharpone likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This side or that side up opinion is what I would think as well. Then again, I fly by the seat of my pants with no real experience.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    You could always speak with the gasket maker , I'll bet they'd have an opinion
    firstinsteele, Budget36 and Sharpone like this.
  4. Mike VV
    Mike VV
    from SoCal
    Why...of course...he did !!!
    That's the FIRST...place this type question should be asked !
    Mike
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Is the gasket symmetrical so it can be put on either way? I always spray both sides of head gaskets with copper coat and I put it on real heavy….
    Fogger, rod1, RICH B and 4 others like this.
  6. squirrel
    Does it have coolant p***ages through the gasket?
    Does it have a pressurized cooling system?
    Sharpone and porkshop like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Ok here is an image I found of an Auburn gasket. looks symmetrical also looks 100% copper. So probably not a pressurized cooling system then?
  8. Joe H
    Joe H
    My thinking is the softer side of the gasket takes the irregularities blocks so the head can have a flat surface to seal against. Copper coat on both sides and solid copper on the head side.
  9. 57JoeFoMoPar
    57JoeFoMoPar
    I've always understood "rings up", as in against the head, not the block. This way if there is a failure and something needs to be resurfaced, it's the head and not the block. While I agree with you that the seal is better along the clamped side (the block) and that's why the blocks are O-ringed in turbo and high cylinder pressure applications, pretty much everyone I know in both nostalgic engines and late model mustangs go rings up.
    I had a similar situation with my Olds 324. I went rings up, sprayed it down with copper spray gasket. Torqued down to spec and sent it. 4 years and like 50K miles later, no issues at all.
  10. Spray both sides of the gasket with 2 light coats and 1 thick coat of Copper Spray.
    rod1 and Sharpone like this.
  11. Rickybop
    Rickybop
    Don't mind me.
    I'm here just to listen and learn.
    And mooch beer.
  12. theHIGHLANDER
    theHIGHLANDER
    Gasket supplier says do whatcha like, no preference. Didn't make it easier. Yes Mark, symmetrical and not pressurized. Block is fine with no issues, head is perfectly flat checked with a machinist's straight edge at any and all angles. This was a coolant failure. Spraying both sides is interesting. I've done that on other stuff. The old gasket shows the "bite" of the head and deck machining, which is why I thought to spray just 1 side. I too have never had a gasket fail from the spray. My Duramax went on dry both sides, an imperative according to literature but it's 17:1 compression too (!) and specified left/right, engine side. My racer with 14:1 was also dry, but used the tried and true Fel-Pro blue with the rings at the cylinders. Over 400 rounds, no fail. This is different, I don't ever want to see it again for this issue and in spite of what some might say I value conversation about it. Now I might just spray both sides, yet I'd hate to impair the dead soft copper abilities. Let it also "tooth mark" from the head cut. Maybe a wee bit heavier on the comp/seal ring side. I don't normally have such deep thoughts on this. An older fella told his grandson he used a very thin coat of grease both sides to allow the gasket to slip and squeeze into place easier. Makes sense but I can't see that approach on anything but a steel shim style gasket. Good stuff so far...
    Moriarity and Sharpone like this.
  13. Jack E/NJ
    Jack E/NJ
    from NJ
    Grease. My favorite green grease. Slathered thick on everything. :)
  14. BJR
    BJR
    I have read that the old timers from the era of the Auburn used gasket shellac, or aluminum paint on head gaskets. Not sure what exactly gasket shellac is though.
    SS327, theHIGHLANDER and Sharpone like this.
  15. Sharpone
    Sharpone
    Xs2 on the copper, cheap aluminum paint with high aluminum content works well also. Too bad Cometec doesn’t have a MLS gasket for your application they work really good on aluminum head - cast iron block engines, they are pricey but worth the money IMO. They probably can custom make a gasket.
    Dan
  16. squirrel
    I'd put some type of sealer on both sides...either the copper paint stuff, or even brush some non-hardening sealer around each coolant p***age.
  17. theHIGHLANDER
    theHIGHLANDER
    Gasket shellac is like Permatex aviation or Indian Head. The nasty brown **** nobody likes, except me that is. And yes, in my childhood I recall Dad using silver Rustoleum to seal a head gasket.
    BJR, SS327, RICH B and 2 others like this.
  18. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    All of my flathead ford v8 engines I built for myself(probably upwards of 12-15) over a 50 year period I made sure I had a copper gasket sheeting on the top and bottom of the gasket with some form of ??? Composite material sandwiched in between the copper uppers and outers. I also installed them DRY as in NO coating of any kind and if a problem arose the head in question could be removed and REUSE THE SAME GASKET AGAIN. I even went so far as to reuse the same USED gasket on a different block. Never did have a failure of any kind!! I also never torqued over 50 ft pounds in all of those engines. Some were under 4-5-6 pounds pressure caused by the supercharger,never had a problem sealing up. IMG_2200.jpeg IMG_0322.jpeg
  19. chicken
    chicken
    from Kansas
    This^^^^^^ is what always works for me. Only 55 years experience so far so buyer beware.
  20. Hemi Joel
    Hemi Joel
    from Minnesota
    Is the motor supercharged? If not with low compression and non-pressurized coolant, I don't think that thing's going to leak no matter what. If it is supercharged, they don't make that much boost anyway so I think you're still pretty safe. I would just spray the permatex high temp copper onto the copper side of it and put it in either way.
    rod1 likes this.
  21. Adriatic Machine
    Adriatic Machine
    I love the Permatex Aviation gasket shellac. It goes on thin and smells just right. I put it on my pancakes.
    theHIGHLANDER, rod1, SS327 and 2 others like this.
  22. 73RR
    73RR
    I'd use Copper Coat on both sides and I lean toward the ring up.
  23. Dan Timberlake
    Dan Timberlake
    I think Permatex #1 dries hard, like the small dark bottle of Indian Head I bough back in around 1965.
    Some sources mention it is intended for metal to metal joints.
    The later Permatex #2 and #3 are non hardening .
    Probably more appropriate for gasketed joints, especially when there will be differences in thermal expansion, like aluminum heads on iron blocks, and probably even iron heads on iron blocks.
    When folks enthusiastically endorse Hylomar, I think they've been working with one or another flavor of Hylomar "Blue, which are also a "non-setting". It is interesting and actually confusing that some Blues are "High-performance, non-hardening, and non-setting gasket sealer" while others only say "Non setting jointing compound".
    And Hylomar these days has a full range of products including RTV and anaerobic thread lockers and sealants.
    https://hylomar.com/products/
    warbird1 and Adriatic Machine like this.
  24. deathrowdave
    deathrowdave
    from NKy
    Copper Cote is your friend
    chicken and Sharpone like this.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Here's a ? , are you trying to enhance sealing against water or against compression ? I'm not aware of any sealant that seals against compression . Many claim to seal against water .
  26. theHIGHLANDER
    theHIGHLANDER
    Water. Yes, supercharged, no, not the least worried about boost.
