Head Gasket?
Discussion in 'The Hokey Ass Message Board' started by 63FalconFutura, Jun 18, 2010.
  1. 63FalconFutura
    63FalconFutura
    from Socal
    Just would like your input on what head gasket i should get for my 260 bored 40 over
  2. 63FalconFutura
    63FalconFutura
    from Socal
    prolly a simple answer but this is my first engine build
  3. 63FalconFutura
    63FalconFutura
    from Socal
  4. Glen
    Glen
    MLS head gaskets require a very smooth finish on the block
    If it is not a high compression I would not run that
  5. johnnie
    johnnie
    from indiana
    Just to make sure of your math. Bored 40 means .040. So it would be 3.840.
  6. 63FalconFutura
    63FalconFutura
    from Socal
    well looking like a dumb*** well i guess its the price of learning
  7. sstang06
    sstang06
    I agree, use a Fel-Pro composite gasket if available. I've only seen one engine lately using a MLS that didn't leak. Leave them to race only engines making over 500hp that will be torn down frequently.
  8. Glen
    Glen
    Would you like to see the shiney brand new set of cometic MLS gaskets hanging on my wall?
    :D
  9. 63FalconFutura
    63FalconFutura
    from Socal
    ok well in my searching all i could find was victor- reinz makes a 4.040
  10. johnnie
    johnnie
    from indiana
    Bore size is much better. I as well as others, have developed our own methods for gasket preparation. I see this is your first build so I recommend you follow the instructions, that are with the gasket, to the letter.
  11. 63FalconFutura
    63FalconFutura
    from Socal
    Thanks for the advice
  12. Mr48chev
    Unless it is something with a lot of special pieces in it such as high comp pistons and head work why get **** about it. just buy a quality full rebuild gasket set and be done with it. The Felpro Composite gasket that comes in a complete gasket set (make sure it has it in it) will work fine and buying gaskets one at a time will break the bank in the long run.
  13. David Chandler
    David Chandler
    How about 289 gaskets? If you used them you could get creative with opening things up around the valves etc.
  14. pdq67
    pdq67
    Does For or Mr. Gasket make a .020" thick steel shim headgasket like our old Chevy V-8's have used stock for so many years? Or even like Fel-pro's #1094 .015" jobbers?
    Worried about them leaking, then daub a bunch of Indianhead on everything and cinch down in like 4 or 5 pulls and then retorque at least once over a hot and cold cycle.
    I'm almost **** so do it at least 3 times over as many heat cycles.
    pdq67
