Hot Rods head lites flashing off and on ?
Discussion in 'The Hokey Ass Message Board' started by putz, Aug 15, 2025.
  1. putz
    putz
    from wisc.
    damn , I can,t figure this out driving turn head lites on a few minutes later head lites flashing on and off like I,m using the emergency flasher , any one have this trouble ??
  2. studebaker46
    studebaker46
    do you hear any thing clicking? could be relay or possibly a ground issue
    Just Gary likes this.
  3. FrozenMerc
    FrozenMerc
    I would think it is likely a ground issue. Something is causing a bit more resistance than the system is designed for. The extra resistance causes something (perhaps the same item, perhaps not) to heat up until it it expands enough to open the circuit. Once the circuit opens, no current is flowing and said part cools back down and contracts until the circuit is once again complete. Rinse and Repeat.
    Turn your lights on, and start feeling around for something hot, perhaps a switch, relay, connector, ground stud, etc.
    osage orange, putz and Just Gary like this.
  4. squirrel
    Some headlight switches have built in circuit breakers, so when the current is too high, it shuts off, then cools down and turns back on.
    you could give us a lot more info about the car, so we might be able to help you figure out what's going on.
  5. Hotwyr
    Hotwyr
    If it's a stock type headlight switch, GM or Ford, either, the circuit breaker in the switch is bad. Turn them on high beam and it will probably start flashing sooner since it is drawing more amperage. Be careful if you try to touch it. They get hot.
    osage orange, putz and 19Eddy30 like this.
  6. garyf
    garyf
    90% of the time its the dimmer switch or its connector melted, tripping the headlight breaker.
  7. 19Eddy30
    19Eddy30
    from VA
    Like other said above ,
    If light's completely turn On /Off.
    A Circuit breaker.
  8. winduptoy
    winduptoy
    Yes, very likely the circuit breaker doing its thing to protect the wiring...you have something in the lighting circuit to ground
  9. saltflats
    saltflats
    from Missouri
    My 65 chevelle would do that after I installed halogen head lights. Made for interesting driving.
    osage orange and hudsonmand like this.
  10. Paladin1962
    Paladin1962
    Floor mounted dimmer switch? That's your problem.
    bobss396 and osage orange like this.
  11. hotrodjack33
    hotrodjack33
    I agree, check the dimmer switch...they are the weak link in the headlight circuit.
  12. lostone
    lostone
    from kansas
    Old pick up I used to have started doing that, on mine it was the floor mounted dimmer switch. Replaced it and problem was gone.
    osage orange and putz like this.
  13. Rockit53
    Rockit53
    from Berwyn, IL
    I had that problem at one point too. Couldn’t find anything wrong checking the wiring and switches. Added relays and never had the problem again.
    Squablow and osage orange like this.
  14. theHIGHLANDER
    theHIGHLANDER
    This is all worthless chin music if we don't know the car, switch, dimmer, etc...
  15. hudsonmand
    hudsonmand
    If Halogen lights need to install a relay in system
    saltflats, osage orange and putz like this.
  16. jamesgs4
    jamesgs4
    from denver
    I'll bet you got some blinker fluid mixed into your headlight grease. Flush them out and refill with the correct juice.
  17. Squablow
    Squablow
    I just went through this with a slightly off topic GM car. Low beams always were fine, high beams would flicker after they were on for about 4 minutes.
    I replaced the headlight switch, no change, I did the dimmer switch as well, no change (and I bought an NORS Made in USA one too, I've heard some of the new replacement ones are ****) I changed every headlight bulb with some NORS ones I had, cleaned every connection, etc. I checked grounds and even added a couple more.
    The wiring in that particular car was comically small gauge for the headlight circuit, and it ran from the engine compartment inside to the switch, then to the floor switch, then back out to the headlights, an awfully long way to go through tiny gauge wire, lots of room to add up tiny bits of resistance until the breaker just couldn't handle it.
    I got frustrated and added relays, that did fix the problem. I did a proper job, with heavier gauge wiring and inline fuses and whatnot. It did feel like a copout, since at one time, the original system did work, but I couldn't find any other faults.
    Without knowing what your vehicle is and what parts it uses, it's really hard to say. But those are the things I checked/replaced and that's what eventually cured the issue.
  18. 37slantback
    37slantback
    My 64 Olds did this exact thing. The negative battery cable had a smaller 8 or 10 ga wire to the body. It was all frayed away. Of course flashing happens when State Patrol was p***ing by.
  19. BJR
    BJR
    My 54 Buick with halogen bulbs did that after a few miles with the headlights on. The lights would start to go off and on about every 30 seconds. It was the circuit breaker on the headlight switch. I cleaned the points on the breaker and bent the part that the points were attached to just a little, to put more pressure on the points. Fixed the problem. I also put a 30 amp fuse after the switch in line to the dimmer switch as a safety, if the breaker didn't work in case of a short.
    osage orange likes this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Everybody likes to throw **** at the wall , especially big they're clueless . In this case due to lack of info , everyone is clueless .
  21. 1971BB427
    1971BB427
    from Oregon
    Had this happen with a brand new headlight switch after just 6 months. I got to a auto parts store and bought a new headlight switch and swapped it out in the parking lot. It was a typical 60's GM style headlight switch, and once replaced the problem never happened again.
  22. RmK57
    RmK57
    My 57 has a block on the fender apron that all the wires for headlights, park lights and signals lead into. Maybe something loose or cracked?
  23. gimpyshotrods
    gimpyshotrods
    Install relays.
    I run one for high, and another one for low.
    I run thermal breakers, but one for each filament. Yes, it's overkill, but I never have problems.
