Technical Header Bolt Hodge Podge
Discussion in 'The Hokey Ass Message Board' started by blowby, Feb 13, 2020.
  1. squirrel
    Just be sure to tighten the bolts a few times after a little use, and again at oil changes or something, until they don't loosen any more.
    The back ones are where you need a full 90 on the wrench...btdt.
    pitman likes this.
  2. dirty old man
    dirty old man
    Lots of different methods shown on this post to get header bolts tight and keep them tight.
    Just want to offer just one caution note about allen socket head bolts and ball end allen wrenches: Have seen lots of people use that ball end and put a "cheater" on the short end, either to remove or tighten allen socket bolts and you run a risk to snap off the ball and then you have that hardened ball stuck in the hex socket and if it's stuck, you got a real problem.
    alanp561 likes this.
  3. loveoftiki
    loveoftiki
    from Livonia,Mi
  4. There are many ways to keep screws tight....
    alanp561 and blowby like this.
  5. loveoftiki
    loveoftiki
    from Livonia,Mi
  6. Doublepumper
    Doublepumper
    from WA-OR, USA
    ^^^ They worked great for me....
    I like to check them from time to time and using these allow me to easily get a small box end wrench on them. Using bolts with larger heads entailed a bigger wrench and made snugging some some of them up a big chore.
  7. BamaMav
    BamaMav
    from Berry, AL
    Just run cast iron manifolds, no problems with the bolts.:p:D:D:D
    upspirate likes this.
  8. seb fontana
    seb fontana
    from ct
    Some supplier had a header bolt with a set screw in the center that when tightened expanded the slotted bolt end. I imagined a nightmare to remove if the set screw rusted or the hex stripped so I never got any.
