header cone-- teaser tech
Discussion in 'The Hokey Ass Message Board' started by Paul, May 19, 2004.
  1. Paul
    Paul
    Editor
    I'm gunna build me some of them cone style headers for the lil' modified,
    I bought a couple 1-1/2" and one 1-3/4" "U" bends for the primarys and a 6' stick of 2-1/2" pipe all 14 gauge
    today I cut the straight pipe into two 32" lengths that will become the cones.
    I want a longer cone and smaller big end then I could find comercially
    so I'm making my own, plus I just want to see if I can [​IMG]
    here's the first cone;
    first the straight pipes
  2. Paul
    Paul
    Editor
    figured the circumfrence at each end then clamped a straightedge on it
  3. Paul
    Paul
    Editor
    and ripped it lengthwise with the plasma cutter taking a long pie-cut out of it
  4. Paul
    Paul
    Editor
    put in the vise and gradually working from one end to the other several times, closed the gap
  5. Paul
    Paul
    Editor
    cranked the heat up and tacked it with the mig
  6. Paul
    Paul
    Editor
    then made a bunch of inch and a half welds up the length
  7. Paul
    Paul
    Editor
    went back and welded between
  8. Paul
    Paul
    Editor
    ground most of the excess weld away
  9. Paul
    Paul
    Editor
    and held it up to see how it'll fit
  10. Paul
    Paul
    Editor
    the tube measures 1-3/4" at the small end and 2-1/2" at the big end and is 32" long..
    or did I already say that? [​IMG]
    anyway there it is for now,
    Paul
  11. dehudso
    dehudso
    Very cool work. What size is that stude engine?
  12. Paul
    Paul
    Editor
  13. Flipper
    Flipper
    from Kentucky
    That's pretty cool the way you did that. Any problems making it round once you closed the gap in the vice?
    Why such a small diameter cone?
  14. Paul
    Paul
    Editor
    [ QUOTE ]
    [/ QUOTE ]
    that's what the block of wood is for,
    I gently bumped it with a BFH to true it up after it was welded.
    [ QUOTE ]
    [/ QUOTE ]
    I don't want the big megaphone look, the motor is small and the exhaust will be 2"
    or, uh, cuz i wanna? [​IMG]
    Paul
  15. old beet
    old beet
    Paul, would hose clamps work for squeezin that pipe??.......OLDBEET
  16. Paul
    Paul
    Editor
    maybe with a lighter gauge pipe but not with the 14 gauge I'm using,
    at least not with the regular radiator hose clamps..
    I have seen pictures, here I think, of the hose clamp method.
    Paul
  17. Very nice work....boy, would I kill for a plasma cutter !!
    Rat [​IMG]
  18. Paul
    Paul
    Editor
    thanks, but you don't kill for them, you work hard and scrimp and save for one. [​IMG]
    Paul
  19. SimonSez
    SimonSez
    Nice work !
    I had a go at that a little while back. One worked out nice, but the other ended up with a big banana-bend in it [​IMG]
    Anyways, I found that a good way to get them nice and round along the weld was to put a piece of steel pipe in the vice at one end, slide the meg. on and then support the other end of the tube. Then when you hammer along the weld, the tube works like a dolly.
    And if you don't have a plasma cutter, you can cut the tube with a jigsaw.
  20. NortonG
    NortonG
    Great stuff as usual, I really like the small diameter cones.
    I can't wait to see what you have next week.
  21. Great post, Paul!
    I think your whole build up series should be in the Tech-o-Matic!
    Keep it coming,
    Sam.
  22. Paul
    Paul
    Editor
    just an update,
    made the second cone and after a little knocking with the hammer I sanded them with 36 on down to 120 grit sanding discs on the little grinder, then hit them with the DA with 120 to smooth them up..
    They do both have about a 3/16" bow in them from welding but decided to leave it in them, it kinda gives them a little swoop that takes some of the edge off. [​IMG]
    like Novocain for the soul.
    Paul
  23. Flipper
    Flipper
    from Kentucky
    After seeing the cones cleaned up....yeah, they are pretty f'n cool!!!
  24. Jojo
    Jojo
    60's those are rad. We weren't nearly as creative and used the speedway kit. One thought as you mock up the positioning and angle of them cones as they go back. We found that where we tacked isn't were they stayed. They tended to***** in toward the car quite a bit and consequently I've had to go back and heat up and bend them back out resulting in a nice little wrinkle. I don't know if you preheat them on the outer edge when you mock them up or just provide a little extra distance. I'm not sure if the*****-in came during construction, welding the extensions from each exhaust port, or after installation.
  25. Very nice work Paul. Thanks, you just saved me the price of a kit for my 33. Looks like I owe you a cold one next time I make it over your way!
  26. Tuff Tin
    Tuff Tin
    Paul
    Nothing you Can do would surprise me anymore. 10 years of wonderful stuff that I'm aware of. Keep it up and E-mail me the Un-Finished Nats pic and the one of your car.........
    PLEASE! [​IMG]
  27. kustombuilder
    kustombuilder
    from Novi, MI
