Header Gaskets
Discussion in 'Off Topic Hot Rods & Customs' started by Wizard1926, Jun 7, 2024.
  1. Wizard1926
    Wizard1926
    Going to be replacing the block hugger headers on my 26 T with SBC.
    Do you prefer the copper or standard header and collector gaskets ?
    Thanks
  2. Deuces
    Deuces
    I'd use exhaust manifold gaskets.... They last longer period!.......
    The Chevy Pope likes this.
  3. Wizard1926
    Wizard1926
    Thanks ! Hadn't thought about that
    The Chevy Pope and Deuces like this.
  4. 283john
    283john
    I like the drop in ones that hook over the header bolts. Just back off the bolts and pick the old ones out with needle nose pliers. Drop new ones in and tighten bolts back up. No fighting the headers back into place.
    Bob Lowry, WC145, loudbang and 4 others like this.
  5. Wizard1926
    Wizard1926
    Thanks for the great advice.
    I'm actually replacing the headers. The old ones have seen better days.
    Deuces likes this.
  6. 19Eddy30
    19Eddy30
    from VA
    Thick stock OEM style replacement
    Felpro , or Multi layer aluminum reusable for street driven
    Copper for race Application
    Deuces and SS327 like this.
  7. Wizard1926
    Wizard1926
    Thanks ! Looks like stock OEM style it is. Big cost savings over the copper.
    Deuces likes this.
  8. SS327
    SS327
    Mr. Gasket regular old fiber gaskets. Soak them in water for an hour or 2 and install them dripping wet. Start and let run for a while and let them dry out. Resnug bolts after cooling off.
    Bob Lowry and 427 sleeper like this.
  9. Wizard1926
    Wizard1926
    Interesting, have never heard of that technique before. Thanks for sharing !
    SS327 likes this.
  10. SS327
    SS327
    Hot Rod magazine taught me that in the late 70s I think. It has never failed me or my friends I told about it.
    Bob Lowry and 19Eddy30 like this.
  11. rockable
    rockable
    If you use Sanderson headers, you don't need a gasket. As I recall, they recommend a bead of black RTV but you know it burns off.
  12. loveoftiki
    loveoftiki
    from Livonia,Mi
    I’ve had good luck with Remflex gaskets and the locking type bolts
    Bandit Billy and Desoto291Hemi like this.
  13. I always use stock manifold gaskets. And never seem to have the troubles people running header gaskets seem to have often
    Deuces likes this.
  14. swade41
    swade41
    from Buffalo,NY
    I use Percy's mult layer aluminum, they seal like a champ and don't burn out.
  15. Bandit Billy
    Bandit Billy
    My Olds blew through a few sets until I installed Remflex gaskets, that set has been on there for years without leaking. I'll never use anything less.
    Bob Lowry likes this.
  16. Wizard1926
    Wizard1926
    Thank you and everyone for the GREAT advice and information !!!!
    Deuces likes this.
  17. kabinenroller
    kabinenroller
    loudbang and Max Gearhead like this.
