header paint question
Discussion in 'The Hokey Ass Message Board' started by dirty mikey, Apr 8, 2008.
  1. jusjunk
    jusjunk
    from Michigan
    Go to the right source and you can buy coated block huggers cheap enuff that there is no reason to even **** with painting a set..
    Dave
  2. Bull
    Bull
    I had good luck with the same method on some stock cast manifolds.
  3. Groucho
    Groucho
    I go direct. In fact I haven't heard of the VHT primer til now. BUT, I've had really good results with engine paint primer keeping the paint from flaking off my Pontiac cylinder heads right above the exhaust ports
  4. twofosho
    twofosho
    Groucho, tell me more about the engine paint primer. I plan on grinding the block and heads (iron small chamber 2.11/1.76s, can't afford E-brocks) of my 421 smooth (like you see flatmotors done) and painting it slick (to go in my Model A, open engine compartment), most likely with urethane.
  5. Groucho
    Groucho
    Dupli-Color (DE 1612), in spray cans from Autozone. It really helped reduce the carnage on a nicely painted motor near the hot exhaust ports on my Pontiacs. The color may change from the heat a bit, but it's way better than flaking off and leaving bare metal to rust and look like ****. Your "color" will cover better over it than bare iron too
  6. Nelly
    Nelly
    My wife wouldn't let me near the kitchen stove with the headers, so I'm gonna heat them in the BBQ.
  7. breeder
    breeder
    back from the dead///.... gettin closer to this step and was wondering?
    the ceramic coating mentioned above....
    thats the one that looks almost the same as chrome right???
    and .....does it hold up well?????
  8. breeder
    breeder
    and...is ceramic better the chrome plating???? im sure its cheaper then plating!! :O
