Header Paint?
Discussion in 'The Hokey Ass Message Board' started by Mr69novaman, Jan 26, 2010.
  1. Mr69novaman
    Mr69novaman
    So i am being a cheapo on this one but the headers i recently bought only come with a black e-coat type finish, and i didn't want to spend the long dollar on having them coated. So i am thinking of using the POR15 Manifold Cast Grey on 'em. Any one try this on tube headers? i know the stuff is kick a$$ on manifolds? Or is there a better paint to use? all the spray bombs seem to flake off even if you bake em...:mad:
  2. Hyway Hauler
    Hyway Hauler
    Anything you put on them will either flake off or burn off. I've used BBQ paint before on them, it seems to last a little longer. The cast por 15 stuff is designed for what it says on the lable...for cast! I would have kept saving a couple more $ and opt to get coated headers...my 2 cents.
  3. Mr69novaman
    Mr69novaman
    well there not painted yet, but the they are hedman and they didn't even offer them in coated. I believe there is a place in detroit that does the coatings though. Thanks for the tip though, never thought of grill paint before!
  4. ShastaStyle
    ShastaStyle
    from Nor-Cal
    I've had decent luck with DEI high-temp exhaust paint so far.
  5. 61falcon
    61falcon
    you need to get them to bare metal first. i sand blast them to bare metal then paint with high temp paint with ceramic. i get it from auto zone. i think its from dupli color. they hold up really well with no flaking. if you paint over the coating thats on there, it will flake taking your paint with it. i did this to the headers in my falcon 4 years ago and they are still in great condition.
  6. slddnmatt
    slddnmatt
    VHT header paint
  7. sixdogs
    sixdogs
    from C
    Over the years I have tried many things but had the best results with a ceramic grey brush-on header paiint I got from Speedway. The surface has to be really clean like sandblast or just really clean. It stayed stuck and looked fine.
  8. Dan57
    Dan57
    i used charcoal grill paint and it lasted 5+ years
  9. Believe it or not.... your fuel mixture will play a big part in how long that paint will last or just "burn off"
    Get that carb set just right.
  10. I'll always use black paint for stoves/ furnaces.
  11. chopped 35
    chopped 35
    from australia
    i have been making pipes for 460 engines in f series trucks for some years now. i use stove bright hi temp paint, works good and lasts reasonably good too. comes in a range of colours as well. best on blasted surface for good grip. cheers ...........
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sandblast - BBQ paint - 24hr drytime - run engine for about 30 seconds a couple of times, let cool completely (engine included). Has lasted me a long time.
  13. thebronc4019
    thebronc4019
    from New Jersey
    Sandblast then and use the Eastwood high-temp paint for exhaust manifolds. I have had very good results with this stuff
  14. BLUDICE
    BLUDICE
    Dupli-Color header paint was the best results on by old TBucket - and I tried several - scuff the metal real good - then sprayed them!
