1952-59 Ford Headers for 56 Ranch Wagon with 351C 4v
Discussion in 'Off Topic Hot Rods & Customs' started by 50sboy, Nov 10, 2017.
Tags:
  1. 50sboy
    50sboy
    OK...so tried the Patriot header...driver side/steering box problem big time...
    Anyone had any luck with a header requiring less mods than this one?
    Using Anchor mounts for more height...can install forward or reverse them and slam the firewall...
    any help would really be appreciated.
  2. cka7
    cka7
    I used patriots with 84 mustang mounts putting the engine forward with a 351 and only had to slightly simple one tube to clear steering box. I did end up modifying the collector exits by shortening and angling inward but didn't have to, just made for cleaner exhaust hook up. Plus I wanted the larger headers for my stroked 351 versus the Hedman 88400. I had both installed in my car. My photo album shows the difference if you want to look.
  3. 50sboy
    50sboy
    Thanks - Ill check out the mounts. I am mounted forward now with the anchor mounts. Have to lit the driver side up and see if I can get them in. Found single groove pulleys so hope to be able to use a mechanical fan. Thanks...
