Headers on Impala, Clearance Issues, Type?
Discussion in 'The Hokey Ass Message Board' started by Camel City Skull, Jul 11, 2008.
  1. So I gotta 1961 283 V8 with everything stock up there and I would like to throw on the biggest, knarliest headers I can find that will FIT. Will I be stuck with 'block hugger' type? Thanks for any suggestions and thanks even more for links to exact product lines etc. I am wanting to pick up an old, cheap pair for this rod. Ebay kinda deal.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I still see used pairs of '58-'64 Chevy headers at swap meets from time to time. They look like headers intended for use with sidepipes, as they exit almost straight out to the side to clear the X frame.
  3. evilone0528
    evilone0528
    I had several sets on my 62.I found they all fit the same,and as far as headers go,they went on fairly easy.58-64 were all the same as far as headers go.
    EVIL
  4. hotroddon
    hotroddon
    Doug's Headers makes a very cool long tube set for your Chevy, part #D358. Killer quality and a bit of history as Doug's has been around since 1958. Not cheap, but then quality NEVER is!
  5. thanks guys. anyone else?
  6. DE SOTO
    DE SOTO
    Yeah,
    Why the "BIGGEST KNARLYEST HEADERS" you can find for a stock 283 ?
    Headers for this car are really a pain in the ***, And forget about lowering it with the style header i have seen for these.
    I had a '60 El Camino that was slammed & there is no way to run ch***is exit headers.
    Leave the stock manifolds & run Dual exhaust, You will be much happier.
  7. allready got all that
  8. Fat Hack
    Fat Hack
    from Detroit
    Zoomies.
    You need zoomies.
  9. DE SOTO
    DE SOTO
    Maybe the best thing is to remove the Hood & run Tractor Pull Headers on it, Sounds like you dont want somthing that fits... Just something to make Noise & Shock Value.
    Tractor Pull Headers ( they are the biggest & knarliest) & Flame throwers should do Nicely !
  10. ...
  11. CurtRod58
    CurtRod58
    Anybody out there have a set of decent used headers in NorCal? I need a set for my '58 Biscayne.
  12. hodaphile
    hodaphile
    Alliance Vendor
