Headers too low? Advice...
Discussion in 'The Hokey Ass Message Board' started by OldCarPilot, Dec 17, 2004.
  1. OldCarPilot
    OldCarPilot
    from Bel Air MD
    The car has chopped springs up front which drops it quit a bit. I've just put some headers in and I'm worried that they sit too low. If I jump on the front of the car the headers will actually just barely tap the ground, but what about over a bump on the highway?
    Pix...
  2. OldCarPilot
    OldCarPilot
    from Bel Air MD
    2
  3. 40StudeDude
    40StudeDude
    [ QUOTE ]
    The car has chopped springs up front which drops it quit a bit. what about over a bump on the highway?
    [/ QUOTE ]
    Traveling at about 70 mph, those headers will definitely be s****ing...and banging...and getting knocked loose...and if there's something laying in the highway...and you hit it...it's gonna sound like the whole bottom of your car just came apart...
    Rule of thumb (at least mine) is you need 4 inches of clearance under the lowest part of the car (and if that means oil pan, so be it)...and I do a lot of highway'n...anything less and you'll be wishing you had it.
    R-
  4. Kerry
    Kerry
    [ QUOTE ]
    Rule of thumb (at least mine) is you need 4 inches of clearance under the car...and I do a lot of highway'n...anything less and you'll be wishing you had it.
    R-
    [/ QUOTE ]
    Does that include drag plates? ;-)
  5. Paul
    Paul
    Editor
    you won't even hear the noise from bottoming out
    not with open headers anyway. [​IMG]
    those look like the $90.00 Flotechs I had in my ole PU
    I was pretty quick at crawling underneath to stuff it all back together every time I hit something.
    you might want to try a different approch though..
    Paul
  6. 40StudeDude
    40StudeDude
    No Kerry, it doesn't...and of course, if it wasn't for that dead skunk and his skull sticking up too high, I'd still have it!!! That damned thing bent my plate!!! And that was only at about 60 per...
    R-
  7. Kerry
    Kerry
    I never id'd what the road kill was that did it to ya. That was a bummer. Sure glad you were at least able to find the plate.
  8. manyolcars
    manyolcars
    how about a skid plate like jeeps use? mebbe with castors on it ....[​IMG]
  9. Missing Link
    Missing Link
    I think you need to go with a different style or type of exhaust manifold. IMO, that is way too close for comfort. Nothing but a problem looking for a place to happen. What type of car is that anyway? Stock manifolds, block huggers, fender well headers. Other than that I can't think of any alternatives.
  10. phat rat
    phat rat
    start cuttin and weldin. that's way too low mine are about 4" clearence and they still s****e at times
  11. OldCarPilot
    OldCarPilot
    from Bel Air MD
    57 Chevy with the a small block and stock steering. Its been kinda a pain to find things that will fit.
  12. 40StudeDude
    40StudeDude
    [ QUOTE ]
    57 Chevy with a small block and stock steering. Its been kinda a pain to find things that will fit.
    [/ QUOTE ]
    Try S & S Headers and/or Sanderson...S & S make a blok hugger style with the collector right at the top edge of the oil pan (meaning that's as low as the header gets) and angles back to allow plenty of room for the exhaust pipe to make the needed clearance. Works with stock steering.
    Sanderson makes a blok hugger that fits perfectly...works with stock steering too. I've used both as I've gone thru my share of '57 Chevy's...ain't nothing better!!!
    R-
  13. Baumi
    Baumi
    I´ve a 56 Chevy and ran into the same problem when I mounted a set of dropped spindles. It looks funny in the rear view mirror to see sparks fly from under your car at 70 mph on the highway. I had about 2 " clearence. It was even worse when I airbagged the car.
    My solution was chopping the headers about 5", but they are still to low. I can´t deflate the front end under 60 psi without having the car sit on the headers.
  14. chromedRAT
    chromedRAT
    dude, i have like two inches and i have to memorize EVERY road i travel on. s****ing ****s, getting short headers this spring. pisses me off, i thought i was going the extra distance and getting full length ****** headers designed FOR the car. the p***. side is fine, driver's side hangs like 2 inches lower! DEFINITELY do somethin else, you won't have exhaust with em that low.
  15. hudsoncustom
    hudsoncustom
    I think you are going to have some serious s****ing issues. Try running some block huggers and then run the exhaust tubing along the side of the frame.
  16. Anderson
    Anderson
    Just chop 3" out of em, or have Tyler fab you up a one off set.
  17. nzsimon
    nzsimon
    I dought you would get to the end of the street before you tore them off
  18. OldCarPilot
    OldCarPilot
    from Bel Air MD
    [ QUOTE ]
    [/ QUOTE ]
    The other side makes all kinds of odd bends. Wouldn't be as easy on the other side.
  19. 67Imp.Wagon
    67Imp.Wagon
