Headlamp and blinker in one??????
Discussion in 'The Hokey Ass Message Board' started by JAKE'S-Pumpkinella54, Feb 20, 2010.
  1. Ok .. I know they sell these new . thats for the token guy that says things like that ( ha ha ) . But wondering if theres a car thats new that i can get these off of . It for my 53 pick up .. just need round head lights with the blinker in them,.. some has to know ????? the blinker on internationals are so out of place and ugly .... thanks guys ! and ladies
  2. THE_DUDE
    THE_DUDE
  3. Kiwi 4d
    Kiwi 4d
    If you are using Quatz halogen bulbs its no problem to run a seperate wire to a single orange bulb shrouded by a small cover to direct indicator light forward. If you are using sealed beam you are probably out of luck. switch to a decent QH bulb. The indicator is almost invisible till in use.
  4. Ruiner
    Ruiner
    My '40 Plymouth came stock with the turn signal bulb mounted above the headlight bulb, and the headlight bulb had a "window" of clear gl*** on the back side of it for the turn signal bulb to shine through it...I also had a pair of 30's headlight buckets with the same style headlight bulbs in them, but the secondary bulbs were clear and apparently the clear lights were for running lights...kinda neat stuff...no idea if those sealed beam headlight bulbs are still made though...
  5. Zapato
    Zapato
    Remember reading a magazine article probably 20+ years ago and there was a car using the headlight as the blinker, had a wiring diagram with it. Never actually seen anyone do it and not sure if it wouldn't generate a ticket. anyone else remember that or how it was done?
  6. Lazer5000
    Lazer5000
    Just get any round Non sealed beam head light ***embly you like and drill a hole somewhere in the reflector and put in a small amber lamp. Wire it to a switch on your column and you should be alright. I've never tried this but sounds like it should work.
  7. Bad Bob
    Bad Bob
    from O.C. Baby
    Streetrod ****....
  8. gtnrkix
    gtnrkix
    Pretty sure that will work, I saw it in a Roadrunner cartoon once.
  9. I'm not sure where the TS's are on your truck, but if they are the ones just sticking out of the fender like lollipops, I can see why you want to change them.
    But..what you are looking after may be more trouble and $$ than its worth..
    try to find some 50's backups or little round T/s ***emblies off something similar. fit them into the lower grill, front valence, or bottom of fenders. Not sure what the truck looks like again..
    Post a pic. A friend has an international in that year range thats going to s**** VERY SOON..if its not already gone.
  10. bdr1
    bdr1
  11. Ruiner
    Ruiner
    So, using the stock wiring on my '40 Plymouth cons***utes it automatically being a streetrod? Really? Thanks, I'm glad I avoided that...I better go out of my way to add some turn signals so I don't end up looking like a douche...
  12. Ruiner your my new hero . I saw that post too. i have learned to ignore comments like those. those few 3 people that are claim sooo traditional and hard core, are the ones that never relize that they are following rather than lead in anything never mind hot rodding . ... its funny how their posts are usally 2 words long !
  13. cretin
    cretin
    My pops bought these little dealios that attach inside your headlights with an amber bulb, that work pretty good. I don't remember where he got them so I'll have to check and let you know. I remeber them being pretty cheap also. I'll ask him and check back in.
  14. Steves32
    Steves32
    from So Cal
    You can drill the reflector & install a generic bulb holder & stick a 1156 amber bulb in it.
    1156's are traditional BTW. ;)
    If the amber bulb bothers you when off- you can buy 1156 LED bulbs which glow amber when on, but are clear (and invisible) when off.
  15. this is it
  16. seetz
    seetz
    why use the headlights? use the park lights! get a double socket and put that in instead of the single one you got now. put a dual bulb in. wire the turn signal to those, and ready.
    cost: about $10
    time: 1 or 2 hours
  17. tdoty
    tdoty
    That's look sweet with some '49 Studebaker headlight bezels with the TS lnse already there.
    Since it looks like it has marker lights for turn signals anyway, your options are wide open. However, if you get down to the details on the turn signals in the headlights, be sure to post the info. You think the 'binder signals are ugly? I've got a '47 Ford pickup...................
    Tim D.
  18. Steves32
    Steves32
    from So Cal
    Now with a pic of car up. You have options. You have marker lights below the headlight which are already 1156 single element (look like trailer markers?). Either wire those as turn signal or change bulb housing to dual element 1157 & you will have both running lights & turn signals.
  19. paintcan54
    paintcan54
    On my wife's '41 International I used "51 Ford round park lites mounted under the headlites. Looks balanced and worked out good. I have a pic someplace I'll see if I can find it.
  20. Blown Mopar
    Blown Mopar
    from abc
    Drilling a hole in the reflector as several have said should work. You could go to a salvage yard that specializes in imports. I did a tour in Germany and there were several makes of cars that used this technique. Take a tape measure.
  21. cheapskate
    cheapskate
    If you go to 1157 bulbs, consider going to 2057 bulbs. Same size physically, at least 3 to 5 times brighter. Available at local parts stores . Cost around 3or 4 bucks a pair.
  22. arca39
    arca39
    from summit il
    here is something that might work, it is about 1" round and a led. check your local truck parts store they make side marker lights for trucks and trailers that are about 3"long and 1" wide.( would fit great in the grill.imo.)<TABLE cellSpacing=0 cellPadding=5 border=0><TBODY><TR><TD vAlign=center align=left colSpan=2>[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]Description
    <HR align=left width=300>
    • Size: 11/16" dia. x 1-1/4" (H)
    • Required 11/16" hole
    • 12 volt "LED" diode
    • Sold by piece
    • Used with stainless steel light panels or trim places, fiber gl*** or metal body pieces, 1" round display
    • Clear lens & housing
    [/SIZE][/FONT]</TD></TR></TBODY></TABLE><STYLE type=text/css><!--.style1 {color: #FFFFFF;font-weight: bold;}.style2 {color: #FFFFFF}--></STYLE><TABLE cellSpacing=0 cellPadding=0 width=332 border=1><TBODY><TR bgColor=#000000><TD width=64>
    Item #
    </TD><TD width=148>
    Description
    </TD><TD>
    Price
    </TD></TR><TR><TD>
    87451
    </TD><TD>
    Blue Color​
    </TD><TD width=112>
    $13.99​
    </TD></TR><TR><TD height=21>
    87452
    </TD><TD>
    Green Color​
    </TD><TD>
    $13.99​
  23. 4woody
    4woody
  24. KrisKustomPaint
    KrisKustomPaint
    You could go this route if you feel like doing some hunting.
  25. paint can can you post a pic of that . ya i want to do away with the blinker or parking light ... just want headlight ... gust cleans it up ........ but now im think about what paint can 54 did .. need to see a pic
  26. kustom paint nice are and those are too nice for my truck haha
  27. THE_DUDE
    THE_DUDE
    Its dudes like that who roll around in Kias . I got a word for um. Poser.
    The rolled pants and ducktail make that Sorento look so traditional. Lame
  28. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im converting my Model A twolight Head lamps to use the small running light lamp as an amber blinker..I know its not the same but, same idea.
    I dont think its street roddy..i think its a creative way to get a blinker with out having some ugly ***ed blinker that doesnt look like it belongs..
    I call it a simple , clean idea
