Technical headlight adjuster assembly
Discussion in 'Traditional Customs' started by Rod and Wheeler, May 27, 2021.
  1. Rod and Wheeler
    Rod and Wheeler
    from NOR CAL
    what adjuster ***embly to use when in stalling frenched head lights . with rear access to adjusting screw on back inside of front fender? And where to find .
  2. 302GMC
    302GMC
    from Idaho
    Use the screws that came with the buckets. Cut a slot in the rear of screw, drill holes in bucket behind the screws. If you're going to drive year round, you'll want to plug the access holes.
