Customs Headlight bucket interchange 47 Ford car
Discussion in 'The Hokey Ass Message Board' started by chevy43, Mar 19, 2024.
  1. chevy43
    chevy43
    I researched quite a while and it looks like 46 47 headlight buckets are different?
    I'm needing headlight buckets rings etc.for a 47 sedan. What years will fit?
  2. Tim
    Tim
    from KCMO
    Can’t say that Ive ever seen them referenced as different, I guess the trim rings could be different but I’ve never noticed. They should interchange
  3. chevy43
    chevy43
    Are they all fully closed on the back?
    Is see some for sale but there s no closed bucket on the back
  4. Tim
    Tim
    from KCMO
    Yeah there’s bucket with a hole for the wires to p*** threw
  5. Tim
    Tim
    from KCMO
    Trim ring and actual light out IMG_2855.jpeg IMG_2856.jpeg with out the inner ring IMG_2857.jpeg and looking inside the fender at the bucket you can see the wire exiting the bucket IMG_2858.jpeg
  6. chevy43
    chevy43
    Many different years use that bucket?
    Thank you very much for the pictures!
  7. Tim
    Tim
    from KCMO
    I would think at least 42,46,47,48
  8. woodiewagon46
    woodiewagon46
    from New York
    1946 thru 1948 headlight buckets are the same. The trim rings are different, '42 and '46, 21A-13045 are the same and '47-'48, 6A-13045 are the same.
    Tim likes this.
  9. goldmountain
    goldmountain
    I think if you are having difficulty finding headlight buckets specifically for your Ford that it would be very easy to adapt ones from other cars since the 7" seal beam is universal in this era of car. The buckets all mount the same. You might have to drill a few new holes and that is about it. Customizers routinely french headlights with '52 and '53 Ford headlight doors to other makes.
